should this work?
  • deanthedude1977
    • Nov 2010
    • 17
    should this work?
    hi all-----Im thinking of buying an A780 and hopefully with the help of u guys and online tutorials etc should set up ok. I have Vm and a superhub router with 4 ports...I have a VM subscribed box downstairs and an old NTL box up stairs that used to get all channels b4 that ended few years back now just gives me basic channels etc----my question is if I run a cable feed upstairs along with the coax feed I already have up there for old box and get an A780 should all work----will signal be strong enough etc--im currently getting 30mbps--(ive checked with an online speedtest.)................................obvious ly will want the one downstairs and kryptview both to work...thanks for any info......
  • ASEK
    • Feb 2010
    • 1686
    should do if u have old box upstairs just reuse cable for feed for kv then a homeplug or wifi bridge for the Ethernet connection and bobs ur uncle.
    • deanthedude1977
      • Nov 2010
      • 17
      wouldn't just running an Ethernet cable up from router into box work??never heard of wifi bridge if its as good and easier I,ll try it
      • cactikid
        • 12017
        780 needs a coaxial cable feed like the old pre n3 boxes but now need a lan connected to work.=2 cables
        • deanthedude1977
          • Nov 2010
          • 17
          Wouldnt the feed I use for my old ntl box I use work?
          • cactikid
            • 12017
            if its still connected yes then add your lan connection.
