Help with Kryptview please
  • tge
    • 7
    Hopr someone can help here, I'm trying to load firmware onto my Krytview but when I run the loader and select the file I turn off the box but get a message "download not requested" has anyone seen this??
  • madman1983
    • Apr 2009
    • 31
    there is a post on this here: http://www.digital-kaos.co.uk/forums...quested-45154/
    have a look at what has been said on there.
    • wilf
      • 1618
      are you sure its a null modem cable your using or it more often than not a comport problem when using laptop
      • tge
        • 7
        Definitely a null cable used it previously on my Eurovox
        • wilf
          • 1618
          is it a laptop or desktop computer
          • tge
            • 7
            It's a laptop
            • wilf
              • 1618
              so your using serial adapter cable withg the null cable joined 2gether? then have you checked you comport settings
              • tge
                • 7
                It appears to be set to COM1 but I'm not an expert, what is the best way to check this?? Thanks for all the help on this
                • wilf
                  • 1618
                  Press start button
                  Move mouse over My Computer to highlight it, then right hand mouse click
                  Then click on Manage
                  Double click on device manager
                  plug in usb
                  then you should see the ports(com& lpt) click on the plus sign at the side and it will drop
                  down and should say prolific serial usb to (com?) that ? number is what you need to select on the loader it has to match up.
                  • tge
                    • 7
                    Yea, it's Com1
                    • wilf
                      • 1618
                      right try this leave box switched off put the bin file in loader then press start then turn box on
                      • tge
                        • 7
                        Tried that by switching box off at the back, switching it off using the remote cntrl then pressing start on the loader. It appears to search for about 5 secs but then comes up with the downloading was not requested
                        • wilf
                          • 1618
                          should be switched off at back so no power what so ever going to the box, if you have tried that do the device manager thing once more but put the usb in adifferent usb port on puter and try if that, if dont work you havent got the correct driver installed for the usb serial adapter
                          • tge
                            • 7
                            Thanks mate, I'll take it to work tomorrow and try install the correct driver.
                            • bigbadconr
                              cheers,this has help me a lot
