Kryptview Flash
  • bohsfc
    • 7
    Kryptview Flash
    I have just bought a Kryptview 750 but it came with old software so I need to do a re-flash. It seems that I cannot download the Flash software without sufficient posts. If there is a quicker way can someone please point me in the right direction.
  • cityfan1964
    I'm in the same boat!!!
    Guys I'm in the same boat, can any body help...please !!
    • satsmo
      • 6397
      Both sorted I presume
      • bohsfc
        • 7
        Yes, have been able to download the download tool and save the firmware 19032009. However, when I go through everything and click start then turn on the box I get a message stating 'download is not requested' or sometimes 'load file size error'.
        Any solution suggestions please.
        • madman1983
          • Apr 2009
          • 31
          are you using the right com port? check this thread out and follow the guide word by word:
          also if you are using the right com port and still not working, try re-intsalling the drivers for usb 2 serial devise (if u are using 1 that is)
          • bohsfc
            • 7
            Yes, Com 1. Have tried other com's but computer says nothing connected so has to be the right Com port.
            • madman1983
              • Apr 2009
              • 31
              are u using a laptop or a pc? a usb to serial adaptor?
              • bohsfc
                • 7
                I am using a PC with a null modem cable. (RS232)
                • madman1983
                  • Apr 2009
                  • 31
                  hmm.. you sure you got the right null cable? did it come with the box?
                  as per wlif post on another thread, the cables are wired different:
                  null = reverse or cross wired
                  Serial Null Modem 9-Pin Female to 9-Pin Female : Null Modem Cables : Maplin
                  serial= straight wired
                  Serial RS232 9-Pin Female to Female : RS232 Serial Cables : Maplin
                  the load file size error sounds bit odd. the f/w size should be 1280KB.
                  • bohsfc
                    • 7
                    Well turns out that just before I came back and read your post I decided to borrow a cable from a m8 and it has downloaded successfully.
                    Just going through the scan at the moment so will keep you updated if this is successful.
                    • bohsfc
                      • 7
                      Happy days are here again. All sorted, Thanks All.
                      • madman1983
                        • Apr 2009
                        • 31
                        it sounds like u might have the wrong type of the RS232 cable.
                        but good to hear its falshed fine. scan should go through fine also.
                        • bohsfc
                          • 7
                          Yep, all up and running, cheers. Roll on August 8th for all the Premier League action.
                          • lunatic12
                            is this krypview any good?
                            • madman1983
                              • Apr 2009
                              • 31
                              good for what? support wise its the best supported box.
