a780 Big Problem :(
  • moreton
    • May 2014
    • 5
    a780 Big Problem :(
    my kryptview a780 has been down for a good 5 days now, not even bbc works, saying the time is 00:00
    anyone having this problems? i tried putting to default settings but when I search it says TP already exist on everything
  • cactikid
    • 12017
    do you have a live coaxial connection,also what firmware date is on box
    http://www.digital-kaos.co.uk/forums...16082013-2981/ ??
    if bbc dont work sounds like no coaxial plugged in/faulty or outside issues?
    • moreton
      • May 2014
      • 5
      kv 780 16082013 - Downloads - Digital Kaos ??
      Its on the latest firmware, i will check the coaxial cable and get back to you, ty
      • moreton
        • May 2014
        • 5
        Still need help the wires are fine, also I have a neighbour a few doors down, anyone know why? or having this problem? im in Liverpool
        • digicon
          • 8261
          If you have no way of testing the Feed like a Pro Meter via the Coax cable then as cactikid explained it could be a problem outside or VM have cut the feeds
          • moreton
            • May 2014
            • 5
            Probably the latter, need a HD upgrade anyway, any box recommendations?
            • cactikid
              • 12017
              hd box will still give you a blank screen with no signal
              • moreton
                • May 2014
                • 5
                I dont mean Kryptview, I mean any other good boxes on the market you recommend ?
                • digicon
                  • 8261
                  There is only one i know in a similar vain to the KV series and thats the A850, personally i would invest in something like a DM800se clone with a cable tuner
