uddingston 40984 not showing in netid search
  • davie900
    • 4
    I have done a factory reset on my phoenix HD box,but when I do a cable scan the netid for uddingston(40984) has disappeared! I have checked my virgin sub box and it shows 40984.I have scanned using direct feed but sill no joy!
    Can anyone help?
  • cactikid
    • 12017
    if you tried another provider is yours there?
    • davie900
      • 4
      I have tried other providers but still no joy!
      • cactikid
        • 12017
        ok you factory reset and powered box off at rear for a minute, and are on direct feed no lan connected scanning tw?
        if you only sub for broadband i wonder do you get a low signal?any variable attenuators on line weakening signal?
        • davie900
          • 4
          I have done a factory reset, switched box off at back and scanned from direct feed and still no joy! I have connected my kryptview 780 and it picks up uddingston(40984)! Do you you think I have a fault on the HD box?
          • McFudge
            • 35
            ive got same problem so its not hd box is there any way you can manually scan in 40984 ?
            its ok i just scanned in for Falkirk area and all back cheers
            • fo08aam
              • 43
              I've got the same issue with net I'd 40980... Its recognised on my kryptview a780 but not on my HD box... Could it be a server issue?
              • cactikid
                • 12017
                no something has changed there and kv know about the problem and is been looked at,the 850 cannot find the top[ bit with info ]
                someone said try scanning Dundee as that worked for them.
