A850 Output Problem HELP
  • Vipex1
    • Jun 2011
    • 23
    Hi guys,
    My A850 has been fine for years but all of a sudden the output is gone t*ts up.
    NOT glitching like everyone moans about on here where the signal lags a bit and comes back etc but the actual hdmi output sends the screen black on every channel or in the menu. It can do it between every 2s and 30s and is now completely unwatchable.
    I've troubleshooted everything I can think of on my TV and kv box i.e. factory reset, off and on at the mains, rescanning, i am up to date on the firmware, had the attenuator fix, new hdmi lead, disconnecting and reconnecting all cables etc etc and still nothing.
    I haven't added or changed any splitters or anything and I'm pretty sure its a box or output issue not the signal in or the ethernet connection as it happens in the menu too not just on channels but been troubleshooting them too. I'm about to throw it out the window!!
    Anyone had this or can suggest anything?
  • Vipex1
    • Jun 2011
    • 23
    ok so I use a scart instead of hdmi and no problems.
    Sounding like something dead on the hdmi front?
    It's almost as if the output signal is trying to change automatically, like when you change between 1080 and 720.
    • cactikid
      • 12017
      did you try reflashing it to see if it makes any difference ,if not any tv repair shop or replacemysocket might be able .
