Bad Ass Glitching
  • billyboy66
    • 87
    #61
    Glasgow is still glitching
    • dutchy10
      • 20
      #62
      oxford still glitching, has been since last week, tried all the usual fixes, reset modem, ect ect to no avail,
      hope its sorted for the weekend, ate having to stream the footie.....
      • gary229
        • 265
        #63
        It's all went a bit Pete Tong again!
        • scouse58
          • May 2012
          • 119
          #64
          been fubar'd all week in kent, every 10 secs, have to wait till fixed.
          • Digicom
            • 190
            #65
            New update file now in Downloads
            Kryptview_A780_15012015
            • cactikid
              • 12017
              #66
              sudden silence again,factory reset as usual folks and rescan.
              • gary229
                • 265
                #67
                do we have to update file first mate, or is it tip top with a factory reset and scan
                • scouse58
                  • May 2012
                  • 119
                  #68
                  try and do a software update from the box, if anyone is having probs trying to update with null cable.
                  • gary229
                    • 265
                    #69
                    Tried updating via box, it now seems to have hung between 0 - 50%, can you stop the update or am I gubbed?
                    • princewmk
                      • Aug 2014
                      • 219
                      #70
                      I just done mine mate as u can see H2 n the X channels are bk including no glistching at all...so brilliant
                      • ASEK
                        • Feb 2010
                        • 1686
                        #71
                        did u flash yours or use remote to update prince? because mines hanging like garry`s
                        • gary229
                          • 265
                          #72
                          mines has hung up online, can you power off and on and should revert back?
                          • ASEK
                            • Feb 2010
                            • 1686
                            #73
                            have tried 7 times hangs anything between 25% - 75%
                            • princewmk
                              • Aug 2014
                              • 219
                              #74
                              Completely flashed it! So basically my PC is in my office so I took the box up n plugged it into the PC using the null cable (Make sure it's connected in com1 check that in device manager of your pc) there's also a problem before pressing download on the loader make sure ur box is plugged n turn on at the bk but not on at the front botton, once u selected the KV file in the loader then press download n Ave your fingers on the on botton in front of the KV n press it to turn it on secs after u pressed the start on the loader then u will have the download start. I had to do it 4 to 6 time before I get it right since I never done firmware with null before. As u can see it's all working fine with H2 n the x being bk including no glistching whatsoever. Try it
                              • princewmk
                                • Aug 2014
                                • 219
                                #75
                                Mine did too but I turned the KV off n restarted the PC then try the same process again n worked on the 8th attempt
