convert what? u use kv downloader connect null modem cable turn kv box off at back open loader load new fix file hit start then turn kv box on at the rear viola.
scrambled or no video
just download update https://app.box.com/s/62ozobbac2b9y72cpqcqfzfkvrmjsfhp save it to downloads, open loader, click where it says download at the top right of opened loader, that will open code send screen, click open on the code send screen which will open your comp, go to downloads find and double click on kv update, then turn box off, press start, quickly turn box back on.Last edited by bofbro; 16 January, 2015, 21:18.Comment
Winrar to extract loader only WinRAR archiver, a powerful tool to process RAR and ZIP files Leave update alone.Last edited by bofbro; 16 January, 2015, 21:36.Comment
the new firmware file is a bin file but it has been rared up like a zip file you will need to have winzip or winrar to open up the file to do that you simply right click the file and select unrar OR unzip "here" it will unpack the fie which you will see is called Kryptview_A780_15012015.bin some people will see it as Kryptview_A780_15012015 when you have that open up the down.tool follow instructions as posted by hitec in the 1st sticky in this section now can you please as asked already address the problems you have to the correct post or threads please it makes helping advice alot easier if those who dont understand what the .zip or .rar is i can create a tutorial video for help. now onto topic i used the firmware today and it helped me out 100% today in gateshead also noticed a few extras like dissplaying channel/time when turning channels. just little things the fw is a cracking release.Comment
