Last call for help before i bin my box :-(
  • TommyTurbo
    • 12
    Hi Forum
    This is that last call of a desperate man before i convert my 700C box to a door stop.
    Recently moved to a block of flats in Liverpool and cannot get my box to work. Its been working for the last 2 years in various flats with and without full cable packages. We have broadband but no min cable package.
    I've tried reflashing the latest firmware AND older versions on the box then rescanning without success. I've also tried scanning on every available provider type.
    This area is virgin but was previously TW.
    I can only manage to get around 11 TP's after scanning i should have around 30 shouldn't i?
    I've attached a picture of the cable connections on the wall incase theres anything you can work out from this
    My box details are
    Arnet 700C
    Software version: Kryptview pv2.0.00
    H/W version: v 1.2.0
    I'm plugging the coax in the SAT1 wall connection then into the input on the box. I've tried the other sat 2 and other combinations of input and output
    Any ideas of what i can do to check if the connection is live or get it working?
    is going to your old house area and ask your old naybours if you can borrow there cable for 10 mins?
    • TommyTurbo
      • 12
      No its not
      • terryuk22
        • Mar 2009
        • 33
        i think you put differnt codes in for tw/ntl
        • smoggy
          • Apr 2009
          • 12812
          you say you have broadband, disconnect cable from modem and connect to your box and scan, see if there is any improvement.
          • Oadbylad
            • 46
            Why are you plugging a cable box into a sat system ??
            just a thought
            • cgscott
              • 3513
              Originally posted by TommyTurbo
              Hi Forum
              My box details are
              Arnet 700C
              Looks like thats exactly what your doing. Plugging into sat. Take a picture of where your broadband comes in and post it up.
              Patience is a virtue.
              • cactikid
                • 12017
                my thoughts exactly,by plugging into a live sat feed dont know what harm may be done,he has a tv socket also that is where the feed comes from that goes into the krypt,you should have got a connector in box to hook up also.
                • DW190
                  Flats sometimes have both Cable and Sat running round and use double head outlets like in the pic. One for Cable and the other for Sat.
                  If you have cable BB make sure you are connected to the same one.
                  • jonnyrod
                    buggered if i know
                    • MICKAH
                      • 96
                      or split the cable BBAND and connect to the box
