at the moment only the 750 with iconnect and 780 had a new update that works.
A700C ArnEt box
Digital Kaos - Downloads - Kryptview_A780_18062010.bin
Digital Kaos - Downloads - Kryptview A750 25/05/2010 Firmware
not to be used on 700 modelComment
I got a null modem cable bothy ends female got the download for the Arnet Loader and the bin file, save the bin file to your desktop. brought my A700C box to my desktop pc, started the loader, press download in the green tab, A box will open, hit the open button in the box and another box will open usually at your desktop, if not navigate at the top of the box to your desktop. click the bin file, hit save open button. now to check what com port your on go to your devise manager hit the cross where it says coms, see what port your plugged into and change it in the box where the drop down box says com1, then enter your port your on, I recomend you stay within com port 1-4. then hit start, imediatley switch on you box and you should see in the box it counting from 1-100% then burning the flash, after you see Done!switch of your box take it back and hook it back up to your tele, after switching on your box it'll take you to the menu press on your provider nthell, tw, chorus and so on then select your area or the area nearest you then automatic search go to sky sports1 and wait if all your channels don't come back then your gubbed m8 n3 is in your area, if they come back on then make the most of it as n3 is coming to you soon.Comment
DW190
Would have been much easier to just put a link to the guide:I got a null modem cable bothy ends female got the download for the Arnet Loader and the bin file, save the bin file to your desktop. brought my A700C box to my desktop pc, started the loader, press download in the green tab, A box will open, hit the open button in the box and another box will open usually at your desktop, if not navigate at the top of the box to your desktop. click the bin file, hit save open button. now to check what com port your on go to your devise manager hit the cross where it says coms, see what port your plugged into and change it in the box where the drop down box says com1, then enter your port your on, I recomend you stay within com port 1-4. then hit start, imediatley switch on you box and you should see in the box it counting from 1-100% then burning the flash, after you see Done!switch of your box take it back and hook it back up to your tele, after switching on your box it'll take you to the menu press on your provider nthell, tw, chorus and so on then select your area or the area nearest you then automatic search go to sky sports1 and wait if all your channels don't come back then your gubbed m8 n3 is in your area, if they come back on then make the most of it as n3 is coming to you soon.
Digital Kaos - Downloads - Arnet Kryptview Loader InstructionsComment
SLOWLY, OUR FREEDOM IS BEING ERASED.
SOON, WE WILL JUST BE A NUMBER.
IF WE DON'T FOLLOW, WE WILL BE ERASED.Comment
Hi to anyone who is interested, but it looks like Belfast has now joined that growing fraternity of the "Lost". My A700C box has just lost most of its channels, confirmed by a friend of mine who also has a A700C box in the same area. I have looked around a number of threads and sites looking for that "needle in a haystack". I will wait til the end of the month in case miracles do happen then I will hold a sad funeral for my poor dead A700C.Comment
