IConn Problem
  • neon2705
    • Feb 2010
    • 6
    IConn Problem
    I have a iconn and just a couple of days ago the only light I ever get it the PWR none of the rest seem to work and only getting FTA channels,
    Anyone else had this and if so any ideas how to fix or is IConn goosed??
  • DW190
    Try rebooting your router and the iconn.
    Has it worked before?
    • neon2705
      • Feb 2010
      • 6
      Tried re-booting everthing and still the same yes it was working before with no problems
      • jumpinjo
        • 869
        bud a faulty power unit was giving me same prob and fixed by using cheapo 12v ac/dc adaptor
        • neon2705
          • Feb 2010
          • 6
          Cheers for that Joe tried that yestersday but no luck
          • cactikid
            • 12017
            Please be advised that if you upgrade your A750 with the 17052010 firmware, make sure your IConnect is powered OFF when doing the new channel scan.
            Only reconnect it and power it back up again once you have a TV signal displayed on the TV (Usually channel 0000).
            Once you power up the IConnect, it should take over the A750 and download a major update from the internet. This is normal and should be allowed to proceed (display shows on both the TV and the A750). Once the A750 display shows the word SUCC it is complete and you may now use your IConnect in the manner in which it was designed. Happy viewing!
            If you get the above wrong, the IConnect will sit there and only display 2 green LED's (power and connection). If this is the case, re-read the above and you have to start from the beginning (re-flash)
            Points to note:
            Faster channel decryption
            Faster fetching of codes (I noted every 2, 5 and 10 seconds on a repeating cycle)
            More responsive remote control
            New menu item which will eventually show website traffic (not implemented yet?)
