new to kv :)
  • cactikid
    • 12017
    #16
    pc with xp and com port should work with null modem cable as this has a cross cable for flashing look here.
    also read last few posts
    • mrmarr
      • 208
      #17
      hearts im using a usb to serial cable not a dedicated com port as my new mobo aint got 1, no its not flashed its brand new ?
      cactikid i have win 7 (tried it on xp too) i have a null mod cable i used it for xbox's b4 the new mobo but now have to use the usb to serial , wich works fine just not for this so im gona buy a internel card got 1 priced at ?15
      i cant beleive it man
      im actually using a usb to serial with a gender changer attached if it makes a diff ?
      • barrowmanandrew
        • 3427
        #18
        m8, that could be your problem,
        you are not using a null modem cable.... the pins are wired diffrently i think..
        a null modem cable should alsways be female to female....
        before you go spending ?15 on a board , i would spend a couple of quid on the right cable...
        have a read on this site
        i'd bet money you are using an rs232 seriel cable which is wired totally diffrently....
        • mrmarr
          • 208
          #19
          i was a little gutd when i got the usb to serial cable and it had a male end cos so does the back of the box ! SO i bought the wrong usb to serial eh
          so i should look for a usb to female serial ???
          please give me a name or link to the correct usb to serial cable m8
          • DW190
            #20
            This is not the cheapest but is one of the better ones:
            You will also need a null modem cable.
            USB to Serial RS-232 DB9 Adaptor Converter Cable/Lead on eBay (end time 30-Sep-10 17:10:46 BST)
            http://cgi.ebay.co.uk/DB9-Female-DB9...item4cf114ccba
            • barrowmanandrew
              • 3427
              #21
              m8, have a look at that link i posted, it shows null modem wiring, if you scroll down it shows rs232 wiring...
              this is the cable, you're after....
              m8 the usb to seriel covertor should have a male end, your null modem cable should be female to female...
              • satsmo
                • 6397
                #22
                You need to use the adapter in conjuction with the null modem cable.
                Sounds like you are trying it with just the adapter and gender changer direct from your pc to kv.
                • mrmarr
                  • 208
                  #23
                  yep
                  so usb to null modem cable :blush: damn ...
                  il try it now
                  also barrowmanandrew and DW190 thanks guys i have both those 2 cables already , im just gona join em and try again
                  • barrowmanandrew
                    • 3427
                    #24
                    i think we might have made a breakthru here
                    hurry up and try it, i'm dying to know
                    • mrmarr
                      • 208
                      #25
                      so i now have a null mod cable attached to a gender changer attached to a usb to serial and still no joy
                      • barrowmanandrew
                        • 3427
                        #26
                        is your null modem cable male to female or female to female?
                        • satsmo
                          • 6397
                          #27
                          There should be no gender changer required? USB to USB port - Male DB9 end attaches to one end of the null modem cable - other end of null modem to kv.
                          • mrmarr
                            • 208
                            #28
                            male to female !
                            i guess i wasnt ready and still need a fem to fem null mod cable .
                            i was fine with my old mobo iv had nowt but probs with this fancy new GIGABYTE mobo, "damn"
                            • barrowmanandrew
                              • 3427
                              #29
                              that is not a null modem cable, it should be female to female....
                              look here
                              • mrmarr
                                • 208
                                #30
                                i will order 1 and pester you guys when it arrives in a few days or fingers crossed it will work
                                VERY MANY THANKS
