Kryptview A780 - Basic Subscription?
  • michaelod1888
    I wonder if anyone can help?
    I have been looking tru various threads but cant seem to find a definitive answer to my query.
    I dont have any TV subscription with Vermin. I just plugged the last box in and the connection seemed to be active.
    Do I need a basic TV subscription for this box and an n3 card or can i just buy the box and plug it in as I did previously?
  • wfhr
    • Sep 2009
    • 61
    If youre last box worked you connection may still be on, Get the box flash it and connect it , Also has to be connected to your router and off you go
    • michaelod1888
      Do you need to put a card in these boxes though?
      • barrowmanandrew
        • 3427
        no m8,
        no card, no sub.....
        simply flash it,
        connect to cable feed and router
        and away you go........
        • michaelod1888
          Originally posted by barrowmanandrew
          no m8,
          simply flash it,
          Cheers mate
          • mdalton444
            barrowmanandrew what do you mean by 'flash it' sorry im new to the forum.
            Also, can you connect to the router wirelessly?
            I used to have a SV3 until it stopped workin and still hav all of the VM cabling in can you kindly explain what i would need in order to get going?
            I am getting a KV a780 and what else will i need?
            Thanks in advance!
            • barrowmanandrew
              • 3427
              by flashing i mean installing the new software.
              yes you can connect to router wirelessly. alot of members are using homeplugs which they say work well.
              if you read through the threads you will find links to all.
              you will need
              for flashing:
              null modem cable and if your using a new pc, then maybe a usb to seriel adaptor
              krptview loader and a780 software.
              connections:
              a means to connect box to router (ethernet cable or some sort of wireless bridge)
              a live cable feed
              thats basically it.
              flash the box, scan for channels
              put yer feet up and watch the tele.....
              • bloodstone1964
                • Aug 2008
                • 33
                get rid of ethernet cable open media wifi bridge is very good and easy to set to your router for about ?23
