just cant seem to do it
  • shakins
    • 11
    can anyone tell me how to set up the kriptview tv box.keeps coming up with stb download not requested tryed everything i think.followed some what was ment to be clear instructions and still cant get it done.need some serious help.step by step instructions please help.please
  • barrowmanandrew
    • 3427
    do you have a null modem cable?
    do you have a seriel port on your computer or are you using a usb to seriel adaptor?
    • kevinmol
      • 59
      Press start to download THEN turn the kv on at the back i had same prob good luck
      • Partymad09
        • 76
        is this box any good for cs on vm where n3..... ie well all the channel work ok on n3 and hi much dose this box go down sever etc please help
        • jumpinjo
          • 869
          start your own thead and stop hijacking others bud
          • shakins
            • 11
            I'm using USB to serial mate
            • Pad578
              • 79
              I had a lot of problems trying to use a usb to serial on windows 7, just could not get the drivers to install.
              if you are following the correct setup then your problem is most likely drivers.
              Have a look in Device Manager on your pc and see if it recognises your usb to serial lead.
              • paddymarsden
                hmm im having a similar problem, might try using an xp machine insted of windows 7
                • Pad578
                  • 79
                  Found this in another thread posted by "LOLa471"
                  I used Windows Vista and the USB-Serial adapter (?2.99) from Amazon said only for Windows XP and below, but it worked. (If you are struggling with drivers, google: "PL-2303 32-Bit Vista Driver Installer")
                  Just make sure under the COMs port settings you set:
                  Baud rate to 115,200 from 9600
                  Change COM# from any # to either 1 or 2
                  Good luck.
                  • shakins
                    • 11
                    think it is my driver mate how do i sort that out could you send me a link.
                    • satsmo
                      • 6397
                      You need to give more info i.e. what OS you are currently using and have you followed the guide in relation to comm port settings?
                      • lola471
                        • Aug 2010
                        • 6
                        Link for USB to Serial Adapter driver
                        USB to Serial Adapter driver downloads and documentation
                        • shakins
                          • 11
                          looked in com port settings and its in yellow.read something about if its in yellow then you dont have the right drive for the software.whats os.sorry mate but im pretty poor on computers.im using windows xp.
                          • Pad578
                            • 79
                            You just answered your own question m8 OS is "operating system".
                            yours is windows xp.
                            you need to follow the link posted by Lola471 and download the drivers for windows xp.
                            • shakins
                              • 11
                              do i need the ethernet cable in. and the box connected to the tv cable to get loading.
