I Connector or new A780 box?
  • kingkermit
    • Feb 2010
    • 99
    I have a kvA750 box but like most people the curse of n3 has hit the area and most channels are disapearing fast.
    Would you advise buying a new A780 box or an iconnector?
    I know a box is 50 quid more but which would you advise and why?
    Is a new box guaranteed to survive n3? Is it easier to set up the A780 or easier to just but an iconnector?
    Just keen to know because I've been very happy with the 3 years service I've had from the A750
    Cheers
  • jumpinjo
    • 869
    cheapest option as good as 780, flash 750 with new firm connect i-conn and job done
    • kingkermit
      • Feb 2010
      • 99
      I haven't been able to physically see an i connector. I presume the one end goes into the back of your box so where does the other end go to?
      • DW190
        The iconnector has three sockets.
        1 Serial to your a750
        2 Ethernet to your router
        3 Power supply to mains socket
        • kingkermit
          • Feb 2010
          • 99
          So presumably the i connector must be really close to your router otherwise you will end up with an ethernet cable running across your house?
          • kingkermit
            • Feb 2010
            • 99
            At the moment I have a white lead that runs from the virgin media box in the wall into the back of my box (this is my aerial).
            If I was to move my router next to the box I would need to use that white lead because it needs to go into the back of my modem.
            If I buy an i connector does 1 of the sockets it has act as an aerial that can just be plugged into the back of the box?
            Sorry for all the questions but I need to know before I go ahead and get one. I've tried looking online for an image so that I can see what leads it has and where they go but I can't seem to find one hence I have to visulaise it which is proving tough
            Sorry to be such a pain
            Cheers for all your help so far
            • kingkermit
              • Feb 2010
              • 99
              Please guys
              • jumpinjo
                • 869
                if router is not near enough to tv/box you need a wifi bridge/homeplugs or a very long ethernet cable
                • kingkermit
                  • Feb 2010
                  • 99
                  Thank you.
                  What about the aerial situation?
                  Does the i connector have a lead that goes directly into the the RF IN port at the back of the box?
                  • smirnoff_rules
                    • 8603
                    wot price r the i-con going for then ?
                    • barrowmanandrew
                      • 3427
                      cost about ?100
                      Lincsat Nick-Nacks
                      • smoggy
                        • Apr 2009
                        • 12812
                        Thank you.
                        as already stated by dw190 the i connector has 3 sockets
                        1. it connects to your box via the serial socket
                        2. it has its own power supply
                        3. it has an ethernet socket to connect ethernet cable from i connector to your router.
                        the cable feed connects to your box as normal via the rf in socket
                        • kingkermit
                          • Feb 2010
                          • 99
                          OK thanks looks like Im gonna need to buy a wifi bridge or summat because Im gonna need that cable feed for my modem. Cheers
                          • smoggy
                            • Apr 2009
                            • 12812
                            not sure what you are saying there but
                            you need a cable feed that is fed via a splitter with one going to your box and the other to your modem
                            • kingkermit
                              • Feb 2010
                              • 99
                              Basically the white virgin media box which is attached to the wall has a white coaxial cable attached that goes into the RF IN port on the back of the kv box. However because Im gonna need to bring my router and modem nearer to the tele Im gonna need to use that white coaxial cable for the back of the modem.
