Kryptview and signal strength
  • lfc84
    • Aug 2008
    • 67
    I have a kryptview and a Scientific Atlanta box on the same line. The line is split, and then a 20db booster placed on the leg going to the Kryptview.
    I cant boost the signal prior to the split since the booster doesnt allow the return path.
    I have gone into the diags on the SA and it says:
    Installation pre hit:
    531 Mhz normal frequency
    attenuation n/a
    remodulation 21
    qam 64
    symbol rate 6.952
    modulation error rate is around 33db
    pre rs bit error rate 0
    post rs bit error rate 0
    input signal level -3dbmv
    signal lock status - locked
    MCNS data
    frequency down 331 mhz
    frequency up 213 (or 21.3 - cant read my writing)
    qam down 256
    qam up qpsk
    S/R down n/a
    S/R up 1.28
    signal level down -1
    signal level up 59
    modulation error rate 37
    The KV is pixelating a bit. Any ideas on what I can do to resolve ?
    Would a 30db booster supporting return path help if i placed it on the line coming into the house prior to the split ?
  • delboy13
    • 415
    sometimes they pixelate when signal is too strong then you need an attuneunator. have you tried removing booster to see what this does
