Connecting from neighbours wireless Internet to my kryptview A780
  • BillyBlue
    • Feb 2010
    • 56
    Hi Guys
    I do not have a vermin broadband connection and
    am trying to connect my kryptview A780 to my neighbour's wireless BT ADSL router. I can already access his internet (with his permission) using my laptop, but how does my A780 access his wifi.
    People have mentioned wireless bridge, but how do i go about it?
    Thanks in advance
  • badapple
    • 2041
    You could use one of these>OpenMedia Wifi Bridge -
    If you have a strong signal on your laptop from your neighbours network then this will work.
    You will first need to set this up on your neighbours wireless network for it to work, so you will need to know his log in/security details.
    I use this on a DM500s and it works well.
    SLOWLY, OUR FREEDOM IS BEING ERASED.
    SOON, WE WILL JUST BE A NUMBER.
    IF WE DON'T FOLLOW, WE WILL BE ERASED.
    • gadgetfiend
      • Aug 2008
      • 355
      the other way is to set up ICS on your laptop and run a ethernet x-over cable to kv from laptop, downside your lappy would need to be on when watching telly...
      • DW190
        Originally posted by BillyBlue
        Hi Guys
        Thanks in advance
        Have you got a Broadband Connection with someone else cause that will work
        • Ruggerplumber
          • 128
          Hi Guys
          Thanks in advance
          Not over sure but maybe good homeplugs will work, you will, however, have to have oone plugged in in your neighbours house to be fed into their router.
          The wireless connection would depend upon how far your KV is from your neighbours router. Maybe someone who's not a technophobe can collaborate or say it's no good!
          Footballers spend 90 minutes pretending their injured. RUGBY PLAYERS SPEND 80 MINUTES PRETENDING THEIR NOT!
          http://www.speedtest.net/my-result/4383088464
          • mikie64
            • 118
            there a thread somewhere.you need a 3g router which can take a 3g dogle wifi...and away ya go..will look for the name of router.....
            • DW190
              Homeplug are not likely to work. If the power supply to the house is a single phase from three phase sub station the next door will be on a different phase.
              • Ruggerplumber
                • 128
                It was worth a train of thought but I knew someone would know, if you could or couldn't.
                • DW190
                  BB the op is not around at the moment but his post doesn't actually say he doesn't have broadband it says he doesn't have VM BB
                  • BillyBlue
                    • Feb 2010
                    • 56
                    Cheers, this worked perfectly. And i've even managed to feed the crossover into my old cable router and distribute via home plugs.
                    'Multiroom' here I come
                    • satsmo
                      • 6397
                      Hope your neighbour is part of your multi room plan
                      • BillyBlue
                        • Feb 2010
                        • 56
                        oops! I never thought of that !
                        • humbaw
                          • Nov 2010
                          hi there can u plesae tell me how u connected using ur neighbours connection im having the same problem...ive tried connecting laptop to a780 via ethernet cable but no joy thanks in adavance
                          • jumpinjo
                            • 869
                            • stewartthemole
                              • 32
                              You need to use a crossover cable as opposed to a standard ethernet cable. This looks the same as a standard cable but is wired differently
