The download(ing) is not requested
  • DW190
    #16
    Originally posted by Grabba
    Hi DW190
    I've tried this option but it tells me failed on the kv display.
    Grabba
    If your sure to have used the S/W Update icon and pressed OK then any failure would be 99.9% the internet connection through the ethernet.
    Is you box connected to your router?
    Have you rebooted your router while the box is switched on?
    Is there an orangy coloured light around the ethernet port on the box?
    • cactikid
      • 12017
      #17
      has he removed that lovely sticker on rear
      [ame=http://www.youtube.com/watch?v=LsEvfBnceiM]YouTube - Setting up the Kryptview KV780 Cable Receiver[/ame]
      • Grabba
        • Feb 2011
        • 14
        #18
        Thanks Guys for your reply,
        I've taken the lovely sticker of the backof the kv box and on the back of the box by the earthnet connection the colour is a Green light flickering.
        I begining to think it could be my firewall settingsI've also just ordered a new usb lead that goes from my lap-top to my kv box so Im waiting for that to arrive.
        Thanks again,
        Grabba
        • cactikid
          • 12017
          #19
          you do know the lan cable needs to go to your router to work.have you looked at that video.found this elsewhere.
          here is a quick guide to installing a780 software using windows 7
          1.connect box to a laptop/pc(i used laptop)
          2.you will get message can not find driver click on help if this don't come up go to devices and printers and right click the unknown device and troubleshoot it and diagnose the problem windows will help you find the driver,just follow it through u want to install prolific driver.
          3.once u have installed driver u will now need to change the baudrate and com port for the device to do this go back to devices and printers right click again on the prolific device go to properties,now click the hardware tab click properties then go to change settings then click the port setting tab from here change the bits per second to 115200 now click advance and change com port number to com 1 press ok and and same with all previous screens.
          thanks to original poster. on windows 7 setup
          • DW190
            #20
            Digital Kaos - Downloads - Prolific Driver Installer
