Kryptview Fix (30/11/08)
This topic is closed.
all channels are back and it seems to be great so greatfull for everyone's help on here!!!hope it has all worked for you as it has for me m8
i would advise that you check other treads as i have done to sort out yur channels cuz it seems like you have done the hard work and it is just a case of reseting your tp's for your area - i feel sure someone will be able to talk you through that
Good luck and u are in the right place for this type of help
Even i am havig problems, when i start down load and press red button at the top left hand corner of the remote followed by the 2 press of red button half way through remote control its displays message dowload not resqusted.
any help to resolves this will be really appriciatedComment
Your problem is that you are pressing the buttons on the wrong order.
It should be the red button twice and then the stand by button in the top left corner.
Hope this helps.
YannosComment
