glitching & freezing
  • belfastdaren
    • Oct 2008
    • 356
    #46
    back up
    fingers crossed and everything else
    • kevlinks
      • 152
      #47
      Originally posted by belfastdaren
      euro night ,busy football matches, wonder if a big film comes out will it be the same
      Could be m8.......but its not live feeds.........something to do with live feeds and alot of viewing........
      • kevlinks
        • 152
        #48
        just kicked off........hope it stays up...........
        • kevlinks
          • 152
          #49
          Get in there fletch..........comeon...........
          • graz6363
            • 11
            #50
            Back on again, whoop whoop.
            • mcintyre1981
              • 12
              #51
              In hindsight your right. I was fully aware of this before I purchased the box!!
              • Scotster
                • 128
                #52
                Man U winning?
                • cactikid
                  • 12017
                  #53
                  ok folks update,it was not the server but the host that went down,swapped areas and came back.
                  • kevlinks
                    • 152
                    #54
                    Originally posted by mcintyre1981
                    This is bullshit!
                    m8......we are all in the same boat, its just the way it is now...........dont take it to seriously..........after all its just t.v.......mind u i was ~~~~ing shouting the house down when i sat down to watch the utd game and it went off after 10 mins then missed all the first half......my better half pissing herself laughing at me with the kids behind her looking at my red face ffffff rant.............
                    • kevlinks
                      • 152
                      #55
                      Cheers for the info m8.......
                      • crezza
                        • Jul 2010
                        • 25
                        #56
                        my box glitches on certain channels for some reason, if i watch gold it will glitch every few minz but if i watch the same program an hour later on gold +1 its fine
                        Signal level is 80 and quality 100 with a booster on, no splitters used either, i use a 3g router and was told that this could be my problem so i brought a 10m ethernet to try from my virmin net and still glitches on certain channels! think i may just have to live with the glitches!!!
                        • kevlinks
                          • 152
                          #57
                          Have u tried it without the booster?......i had a problem with a booster and took it away and now works fine,,,,,
                          signal level dropped abit but worked great after disconnecting booster......give it a go.....
                          • crezza
                            • Jul 2010
                            • 25
                            #58
                            well i brought the booster because my signal was around the 60 mark and was glitching, but i will give it a go without the booster, thanks for your help mate
                            • cactikid
                              • 12017
                              #59
                              sometimes you need to check if you have the latest firmware on your box and do a factory reset and rescan again on main feed no splitters and lan removed,little tip put a sticker on top of box of net id you use as your memory may fail,reboot box and router and see how that goes for you.all info in stickies in downloads.
                              • crezza
                                • Jul 2010
                                • 25
                                #60
                                Yh I've done all that I'm on the latest firmware, I even checked my v.box to see if I was on the correct network I.d
