recording from an a780
  • speedynn3
    • 17
    i have an a780 . is there any way i can record programmes from the a780 if there is can some 1 recomend any equipment i need to use ....i dont need live pause or anything flashy like that..just a simple record while im out...
    thanks in advance for your time
  • DW190
    There is a second scart on the 780 to connect to a DVD/Video Recorder. Your recording device must have a facility for either Scart in or Component in (red whiite yellow). You can set you recorder to record from the source you choose and the box must be on the channel you want to record but you can set this to change channels from the epg (reservation) or the timer.
    • speedynn3
      • 17
      thanks dw190 thats helped a lot
      • kingkermit
        • Feb 2010
        • 99
        What about from an A750 with i connector? Do you have a link for a decent recorder to buy so I can record from any channel when im out?
        • DW190
          750 + Iconnector will be exactly the same as the 780.
          • Jonna123
            • Nov 2010
            Great thanks for the info
