kv780
  • guppyabby
    • 232
    kv780
    him8,iv im new to this i need advice on this,just got kv780,trying to wire up the system but its diferent from 750 which i used to have,thers no ethal cable to plug in from the router,iv no instruction with box,does it need to plug in from pc,if so how do i go on about it.thanx for your advice
  • DW190
    Look on the back of the box near to the switch and you will see a 1 inch square piece of black tape covering the ethernet socket.
    • guppyabby
      • 232
      ur a pal thanx m8 for your help,
      • guppyabby
        • 232
        before i connect will ineed to flash the box if so which file plz.
        • stewartthemole
          • 32
          Hopefully not as many ship with image but others don't, if the latter all the files you will need are in the download section including the loader.
          Personally I would try it staight out the box first before trying to update the bin file
          Connect ethernet cable from port behind tape to your router.
          connect cable feed.
          connect scart lead.
          power up box, it should go to set up screen, select supplier ie ex C/W telewest etc, select region from drop down menu and the do a scan.
          If all is well you will get your channel list if not i'm afraid it a visit to the download page
          • DW190
            The easy way to check if the box has been flashed is press the menu button then installation, (0000 password).
            If the fourth item down is S/W Update the box has been flashed and can be updated online.
            If there isno S/W Update showing the box only has FTA software on it.
            • guppyabby
              • 232
              thanx dw190,yes it isflshed i hve updated with s/w.problem is im only getting 4 channel,iv rescanned ,refactory setted,signal is there as well as quality bar both showing 56-65.can you tell me where im going wrong.or is it the box faulty.
              • guppyabby
                • 232
                sorry to bother you all iv got it sorted thanx to all gud forum people
