hi all just got a a780 because am fed up with me sv7,could some1 be kind enough 2 tell me the correct fw to put on it or maybe even a link! thanks nicole
a780
thanks jumpinjo you couldnt help me with the loader,its been a while since i had 2 use the rs232 lead with the sv 2 and 3 am a bit rusty if i have 2 open the file b4 i use the loader!! thanks againComment
DW190
Try this tut:
thanks for your reply dw190,i am useing a rs232 cable and keep getting "download not requested" have read that tut you sent and noticed a few people had the same problem,think i might buy a usb connection and try that!!Comment
thanks jok yes mate i have used the rs232 cable 2 flash the starview 123 and the eurovox,i also tried the rs232 that come with the box and ive also tried the switch off and on thingy aswell,going 2 give it another try later!! thanks!!Originally posted by JoKYou may end with more hassle using a USB lead.
Have you used the rs232 cable before and know it works? Is it a NULL one? did you get it free with your a780?
Also to add when you were in process of flashing box there is a point were you need to switch box OFF hit the download and switch box back on again.
It catches loads of peeps out that.
JoKComment
DW190
Try different comm port numbers in the loader.Comment
DW190
If its only finding half the channel you are scanning wrong area is most likely. What area are you in?Comment
