A780 HELP
  • bigjerry
    • Mar 2009
    • 16
    A780 HELP
    hey i have a a780, however it keeps going do but usually a factory reset does the job and it comes on again. This time the box will only pick up 7tp and when i put in the rest of the tp it will not save them and will not pick up any channels
    any1 any idea wot could be happenin??
    Cheers
  • DW190
    Cheers
    Do a factory reset and rescan on the correct provider for the area.
    When you have selected the provider make sure you press the green button to start the search for area id's. Then select correct area and press OK
    • cactikid
      • 12017
      if you are losing your channels,maybe you have a poor signal,remember to scan with lan removed and no splitters also.when scanned in insert lan and reboot both units.
      • ab_patel
        • 26
        Hi Folks
        I'm new to this cable lark and have a few questions.
        1) Can the box work with either sky or VM?
        2) Do you need to add firmware or does the new box auto find the stations?
        3) Can the signal be traced back my the cable operators?
        Any help would be much appreciated. And keep up the good work
        ABP
        • joe516
          • 1000
          Originally posted by ab_patel
          Hi Folks
          ABP
          1 vm
          2 yes
          3 yes
          information given is to be used for educational purposes only
          Don't Forget To Say Thanks If You Like My Post
          IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
          If It Ain't Broke Don't Fix It
          • ab_patel
            • 26
            Cheers me mate.
            Another stupid question.
            Where o I get the firmware from and what cables will I need
            Ash
            • joe516
              • 1000
              Cheers me mate.
              Ash
              • cactikid
                • 12017
                [ame=http://www.youtube.com/watch?v=Q2RbdhH7_b4&feature=related]YouTube - Flashing the KV780[/ame]
                [ame=http://www.youtube.com/watch?v=LsEvfBnceiM&feature=related]YouTube - Setting up the Kryptview KV780 Cable Receiver[/ame]
