Arnet signal problems
  • pinkeh
    Hi, my set up consists of a single line which then gets split off to a arnet kryptview with 29/11/2008 firmware, other line goes to another splitter which runs modem and v1rg*n box.
    The arnet box was workin fine (apart from a few freezes a day) but then i had to call vm out as on demand stuff wasnt workin on their box, so the enginner replaced the old dark grey box for a shiny silver one, the problem below has now started.
    The problem lies with my signal it just isnt stable jumpin from 0 to 75 to 13 to 0 etc it may work for really short periods but then just dies and i get bad or no signal displayd onto the screen. Now it doesnt even show any channels and cant find any on a scan or even the tp.
    The vm box is fine and so is my broadband.
    Any ideas on what the problem or a possible fix could be?
  • delboy13
    • 415
    could try the other firmware
    have you swapped it with your virmin box to see if it works there or not
    if it works there check cable connections
    try an attenuetor or booster
