Kryptview 780
  • mister99
    • May 2010
    • 16
    Kryptview 780
    Got this box yesterday and after some difficulty and is now working great
    I put on the firmware 180610 straight away using null modem cable ( let the sofware loader complete fully before pressing close). However when i went to to turn on there kryptview there was no display via scart. there was only a small green dot on the front panel & the remote control was totally unresponsive.
    I heard you had to do a factory reboot but i did not know how to do this. I thought maybe i had damaged the box.
    the next day i tried connecting the box to the pc. again the box was unresponsive with a green dot showing on the display. eventually i turned the box on & off several times whilst trying to connect with the software. all of a sudden the box connected to the pc and started download firmware. the displaying showing 0000.
    I don't understand how this worked as on the instructions for downloading firmware it stated that you had to press the red button on the remote twice then the standby power button ot initiate the download.
    I wonder if anybody knows why this happened?
    anyway a big thx to the guys on this forum for the firmware & info
    Had Itgate tgm 220 before and it was good while it lasted & a shame about the way ended
    However with this box i actually get a few more channels and program software is a bit better...so far so good
  • antsumner
    • 438
    there is a new software update avalible through your remote m8 press menu intstallation 0000 s/w update
    • mister99
      • May 2010
      • 16
      s/w update
      thx , i did this as soon as i got the menu screen up
      • cactikid
        • 12017
        i think maybe a bad flash you got as to my memory box reboots after it flashes,maybe you exited before this happened.
        downloading firmware by null modem cable you dont use remote only the keyboard from pc and box switch at rear only
        • DW190
          Red twice then standby was from the first Kryptview. When it was discovered that powering on after hitting start did the trick this became the norm and certainly the most reliable.
          • robbeno
            • Feb 2010
            • 389
            krypt 780 sv7
            Hi can someone tell me who knows wich is best box the k780 or sv7 ? and do you get box office events on any of these, as ye did on the old starview ? like boxing fights etc
            appreiate any help thx
            • cactikid
              • 12017
              kv780 yes sv no
              • robbeno
                • Feb 2010
                • 389
                hi m8 i ordered k780 i got loader and firmware on desktop got a usb to rs232 do i av to install for the lead to wrk, and im on vista is that ok ?
                cheers bud
                • DW190
                  cheers bud
                  Vista is not the best os for a usb to serial adaptor. Did the adaptor come with a disc?
                  • robbeno
                    • Feb 2010
                    • 389
                    no... shall i buy one with disc ?
                    • DW190
                      No you can download the drivers. Vista and windows 7 should sort them out, when you plug the adaptor in it should self install. As long as it does you may just have to change the setting slightly.
                      • robbeno
                        • Feb 2010
                        • 389
                        i seen one with disc on ebay and is okay for vista only?1.70
                        • antsumner
                          • 438
                          you can download the driver here m8 then just go into your control pannel and change the com port.
                          USB to Serial Adapter driver downloads and documentation
