Kryptview 780 box stuck in update mode
  • lucky dip
    • Jun 2009
    • 7
    #16
    Any help please ,
    cant come out of easy installation screen , goes to network scan and list of network id s just shows allready exists.
    Automatic search shows no channells , then when exiting from complete goes back to easy installation screen.
    P.S. the new firmware is uploaded to the box.
    • cactikid
      • 12017
      #17
      you need to select net id nearest you to scan,lan removed also
      • whiskymincher
        • 20
        #18
        My brother had a similair situation with his new box and it turns out that he had connected his cable feed to the fm port of the cable splitter therefore was not receiving a signal. Once he realised his mistake and piped it up to the tv feed all was fine. Might not be related but worth checking.
        • pizzaman
          • Mar 2009
          • 22
          #19
          i am having same problems
          i have reflashed it and it does exactly the same when i turn it on just says searching for update
          any help please
          • cactikid
            • 12017
            #20
            reflashed with what and have you read the other posts?
            • alex123
              • 832
              #21
              he reflashed with jan files hes going to try fta file as update mode is not in that file and let us know
              alex
              • EAMO 2
                • 1201
                #22
                Top o' the mornin' to you and yours Cacti. Sorry haven't been in
                touch lately, been on away active service duty in Far-East. The're
                still on nagra 1 in SG region & have had a few key-rolls lately so
                anyone without upto date scce & keys had to manually enter keys
                Do you have fond memories of those days in the civilised world
                Satsmo was a bit slack in monitoring SGsta*hub thread so it got
                out of control. In fairness to Satsmo he atoned for his lack of due diligence. When he wielded the axe he was ruthless. No one was spared.He deleted hundreds of posts in thread even some of mine
                When he had SG thread sorted out I then informed him SG users
                had encroached on to 4 or 5 other threads. He went ballistic
                Natural order has now been restored. I PM'd 40 members the files needed to fix auto-roll c/w Dummies guide for Flash-FXP & told them to PM them on to others
                All was fine until member posted links on SG thread. Links had
                to be deleted then & new link PM'd to everyone again. Satsmo's
                head is done in & so is mine at this stage. There is over 5,000
                posts on SG thread now. If you have time read posts #4809 &
                #4932. It's some laugh but you'd have to bring some humour in
                to the proceedings for your sanity alone
                By the way Cacti could you not be more helpful to this troubled
                KV user. Something like this might be of more benefit to him.
                LOOK AND LEARN;
                If KV A780 keeps searching for update; take following steps
                1. Disconnect ALL cables from box & unplug from
                2. Have cup of tea or other bev. (no alcohol 'till box is revived)
                3 Plug in power cable ONLY to KV box
                4 In KV box menu do FACTORY-RESET
                5 Connect Prov TV co-axial cable to KV box
                6 Do an Auto-scan for channels (select correct Prov & Net-ID)
                7 Check are FTA channels clearing (bbc1, bbc2,Itv1, etc)
                8 Connect LAN_cable from router to box ( or homeplugs, etc)
                9 Click OK on SW/update in KV box menu
                10 Unplug power cable from router & KV box
                11 Plug in router power cable & then plug in KV box power cable
                If above steps do not revive box best to Fac-reset box & flash
                from PC with this firmware;
                Digital Kaos - Downloads - Kryptview_A780_18062010.bin
                You can perform S/W update in box menu when box is sorted
                Similar steps to above will sort out KV750 box+i-connector
                Just be sure to allow enough time for i-connector to update
                • cactikid
                  • 12017
                  #23
                  thought everywhere on n3 now ,never thought of n1,think i slipped up again.
                  • EAMO 2
                    • 1201
                    #24
                    Think your beginning to creak at the seams. You can get a fix for
                    most boxes but Alzheimers disease is more secure than nagra 3
                    The civilised world is gone N3 but SG(Singapore region) is still
                    Nagra 1
                    • alex123
                      • 832
                      #25
                      LOOK AND LEARN;
                      http://www.digital-kaos.co.uk/forums...rmware-120981/
                      you should not flash new kv with older firmware new boxes have new chips and require to be flashed with 03/01/11 and before am told am wrong thats from the horses mouth even the fta that i uploaded is new fta
                      • EAMO 2
                        • 1201
                        #26
                        I would prefer to be corrected by other member than mislead
                        another member with advice, Alex. I read your posts & have no
                        doubt about your competence with KV boxes & your connection
                        to KV team. I have posted many times here that I would never
                        object to being corrected. The reason I suggested older firmware
                        is I understood box in question was not new But older box which
                        stuck on S/w update. Again I may be wrong. Either way I need
                        to edit my earlier post with the footnote new box new firmware
                        Keep up the good work Alex
                        • alex123
                          • 832
                          #27
                          yes m8 but new boxes which his is will have new eprom to stop invalid mac so old firmware could screw his box he has just txt me he has got box working so all good
                          cheers alex
                          he got it around christmas so could have been old or new
                          • alex123
                            • 832
                            #28
                            actually eamo2 it was your link that fixed the box he loaded the older firmware and is now updating through lan .
                            cheers alex
                            • EAMO 2
                              • 1201
                              #29
                              cheers alex
                              Once his box is up & at it again that's the main goal of forum &
                              appreciate your input re NEW BOX-NEW FIRMWARE as I was not
                              aware your FTA firmware upload was actually new release I just
                              assumed FTA f/w was dated from release of 780 box Once again
                              Alex it has been proven ASSUME NOTHING & if not sure ASK
                              Am a bit dubious about old firmware possibly causing issues with newer boxes. Since release of KV-700 box KV tech-team have been at top of game in non-linux cable boxes so would be very surprised if any 780 box would have issue with any 780F/W
                              If F/W is not fit for box loader should not allow flash. Having said all that I do not dispute what you were told by "horse"
                              Kv team should tidy it up & if problem cannot be remedied then
                              BOLD warning should be attached to download links
                              Takes long time to establish good rep but bad rep can be obtained very easily Think we are on same plane Alex & I think you will agree If user loads A750 F/W on A780 box, BAD CALL
                              but if ANY A780 F/W is used on ANY A780 box it should not brick box. If F/W is that critical newer boxes should be A790-c &
                              newer F/W should be A790-c fix
                              Am avid admirer of KV tech-team, They were months ahead of
                              all non-linux boxes with N2 FIX in Eire, second only to ITGATE
                              team. Being 2nd to Itgate team is like winning the Olympics
                              Will read your posts as always Alex, I love learning once it does
                              not involve going back to college
                              • pizzaman
                                • Mar 2009
                                • 22
                                #30
                                yeah eamo 2
                                works spot on now and updated fine
