I need help with my KV780
  • foyshal
    Hi Everyone I need help with my KV780, I have hit a brick wall. I'm using a USB serial port adaptor and null modem cable to connect my a780 box via Vista, assigned the ports and switched off the box from the back b4 clicking the start button still no luck, when downloading I'm always getting a messaging saying "The downloading is not requested" a message appears above the loading box saying "Read REQ failed". I've been through the forum and no luck. Would appreciate any help!
    Thank you in advance.
    Foyshal
  • hearts
    • May 2010
    • 96
    Are you sure it's not flashed already?
    • EAMO 2
      • 1201
      Foyshal
      Read thru tut & esp section re com/ports with vista
      • albaniansniper
        • 132
        Foyshal
        Similar problem here? http://www.digital-kaos.co.uk/forums...rmware-153111/
        * Dreambox 800 HD se
        * Kryptview a780
        * Triax TD110 1.1m Solid Dish
        * Birds: Eutelsat 16e/ Astra 19.2e/Astra 28e
        • mrmarr
          • 208
          i had the EXACT same problem m8, it seems some pc's dont like the usb to rs cable i had to buy the internal pc card then it worked 1st time
          • EAMO 2
            • 1201
            Vista poses many problems but if you install correct vista driver
            for USB-RS232 cable should work OK
              correct m8 plus are folks getting a disc with drives on ?..
              • brainwave
                • Mar 2009
                • 209
                Some do some dont, but you can find drivers on the net anway.
                • DW190
                  Let me google that for you
