help with wireless connection pls...
  • saj1985
    • 785
    hey peeps,
    i've got a belkin wireless gaming adaptar this morning,
    i've installed the cd and followed the instructions,
    and connected the gaming adapter to my openmedia box,
    i typed in the ip of the openmedia box in flashfxp but it would not connect!
    how do i connect and configure the netgear wireless router to work with the wireless gaming adapter?
    im confused?
    please can someone help?
    p.s in my network connections the internet gateway is disabled
    Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
  • saj1985
    • 785
    anyone?????
    • saj1985
      • 785
      when i go to run and type cmd and type ipconfig/all
      this is the info i get...
      Windows IP Configuration
      Host Name . . . . . . . . . . . . : ***-***********
      Primary Dns Suffix . . . . . . . :
      Node Type . . . . . . . . . . . . : Unknown
      IP Routing Enabled. . . . . . . . : No
      WINS Proxy Enabled. . . . . . . . : No
      Ethernet adapter Local Area Connection:
      Connection-specific DNS Suffix . :
      Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
      Physical Address. . . . . . . . . : **-**-**-**-**-**
      Dhcp Enabled. . . . . . . . . . . : Yes
      Autoconfiguration Enabled . . . . : Yes
      IP Address. . . . . . . . . . . . : ***.***.*.*
      Subnet Mask . . . . . . . . . . . : 255.255.255.0
      Default Gateway . . . . . . . . . : 192.168.1.1
      DHCP Server . . . . . . . . . . . : 192.168.1.1
      DNS Servers . . . . . . . . . . . : 192.168.1.1
      Lease Obtained. . . . . . . . . . : 20 December 2008 12:30:57
      Lease Expires . . . . . . . . . . : 21 December 2008 12:30:57
      any ideas peeps?
      i really need help,
      please!
      • max_gee
        • 108
        chnge the ip on the openmedia so its set to dhcp then restart the openmedia and go back to ip settings and see what the new ip settings are
        • saj1985
          • 785
          thanks for replying for a start mate
          anyways on the openmedia box i put the ip to 192.168.1.1 and ensured that dhcp was set,
          after i rebooted i had a look,
          and its automatically changed to 192.168.1.10 and dhcp is still on,
          i have ensured the dhcp on the gaming adapter is on too.
          i have installed the cd that comes with my gaming adapter but
          how am i suppose to connect my wireless router to the gaming adapter wirelessly???
          do i have to configure settings on my router??
          am confused!
          • saj1985
            • 785
            please can somebody help???
            • caveman_nige
              • Feb 2008
              • 4920
              will have a read and comeback to soon mate..
              Ok what i do is I have my xbox and a dreambox connected using these belkin jobbies..
              I set a fixed IP in each of them
              So my netgear router is 192.168.1.1
              my pc and laptops are on dhcp and pick up whatever
              My Dm has a fixed IP of 192.168.1.5
              My xbox has a fixed IP of 192.168.1.7
              I set these fixed ip address in their wireless gaming adapters.
              If i remember rightly the software set up prog they give you is a little crap and does not save it into the belkin so well. So i did it 2 or 3 times.
              I had to switch off the laptop wifi when i set it up as it was possible the router was getting confused having two devices using the same hostname etc.. The disconnected the belkin from my laptop and connected it to my xbox/dm and voila it worked.
              I sed fixed ip on these as i saw no point in using dhcp due to the amount of devices i have coming on and off my network and that i wanted to port forward the device in my router to access it from the internet.
              Does this make sense..?
              • saj1985
                • 785
                it does sort of make sense!
                ok, so for a start,
                i'll try and copy your connections because,
                i also have a netgear router with the same ip - 192.168.1.1,
                so what i'll do is change the ip from dchp to a fixed ip in my gaming adapter to 192.168.1.5,
                and on the openmedia box to a fixed IP of 192.168.1.5 (i'll untick dchp and it will be a fixed one exactly like your!)
                so in a nutshell the ip's on the gaming adapter and on my openmedia box will be the same
                now in regards to the port forwading bit confused with this bit,
                do i have to put the same ip and port number
                in the port forwarding page of my router to allow internet access???
                what exactly do i have to do??
                • caveman_nige
                  • Feb 2008
                  • 4920
                  The port forwarding is in your router, you forward the ip address of your box on port 80. this means that when you type in the external ip of your router the openmedia will come up with its webinterface logon. To access your router remotely you need to type the external ip and the port 8080 e.g ***.***.***.***:8080
                  i do not have an openmedia box so I am unsre of the capabilities etc..
                  Lets get your box working on your internal network first..
                  • saj1985
                    • 785
                    ok for a start i'm going to set the ip on my gaming adapter and the openmedia box on as a fixed ip of 192.168.1.5, which i shall do right now!
                    under my router page you want me to then go on port forwading,
                    click on add custom service call it 'openmedia',
                    for service type do i choose 'tcp/udp' or 'tcp' or 'udp'??
                    do i also put starting ports as 80 and ending ports as 80?
                    put the ip 192.168.1.5
                    am i on the right sort of lines???
                    • saj1985
                      • 785
                      mate i have changed the ip on the gaming adapter to 192.168.1.5
                      (after a lot of ~~~~in effort!!!!!)
                      now on the openmedia i have also put 192.168.1.5 as the ip,
                      what do i put the nameserver and gateway as on the openmedia box??
                      p.s this is fekin doin me nut in!!!!
                      anyone in birmingham that can come and help??
                      pleaseeeeeeee!
                      • ianmac
                        • Oct 2008
                        • 922
                        pleaseeeeeeee!
                        I don't think you want the same ip on both, as it will clash.
                        Silly question, but have have enabled "wireless" on the router, and it it is on have you got anything else wireless that you can scan with, to see if you can find your router. i.e. PSP, Wii, Mobile phone, coz sometimes it is better to work backwards to see if the router is putting out a signal...
                        • saj1985
                          • 785
                          ian mate, within the gaming adapters settings you can search to see wireless connections,
                          and i can see my wireless connection available with the strength and encryption type next to it,
                          so i assume 'wireless' is enabled on my router
                          p.s i have not done anything with port forwarding on my router web page
                          • caveman_nige
                            • Feb 2008
                            • 4920
                            As i said before, ignore the port forwarding for now... That is for another day.
                            Just get your box talking to your router for now.. Put the router IP address in as the gateway, will not heard to put it in as the nameserver also.
                            • saj1985
                              • 785
                              ok nige mate,
                              on the openmedia box i've put the openmedia ip as 192.168.1.5,
                              which is the same as the gaming adapter,
                              i have unticked dhcp,
                              subnet mask is 255.255.255.0
                              put the gateway as 192.168.1.1
                              and left the nameserver as it is which is 127.0.0.1
                              what next?
                              p.s the wireless sign is flashing on the gaming adapter
                              i think it means its connected wirelessly,
                              but i could be wrong!
