can only view free channels helpp plzzzz
  • woodgm
    • 14
    hi ive got an open media 500cs box was all working till the channels went of so i did a system reset and then wehn i scanned for channels only freeview channels will come on and theres a blue lock key in the bottom left plz can any1 help the guy i got this of said 20 pound to put bck on which hes already conned me into fixin it wen it goes of not spending no mre money on it so this last resort plz some 1 help cheers
  • mickarick
    • 107
    Dont pay him ?20 m8 go to the downloads section and download dream up also download an 500 c image use the the dreambox board on here for help .
    • woodgm
      • 14
      cheers for reply mate where do i get the image from ive got the dreambox program just need img nw cheers
      • mickarick
        • 107
        Digital Kaos - Downloads - Dreambox
        • woodgm
          • 14
          got the digital kaeos fimware on and its all on but the channels like sky sports etc channels u pay for have a blue lock in the corna n still wnt show up cheers for help so far
          • woodgm
            • 14
            just put commando image on which the lad tht sent me it said will work loaded it on but still channels locked cud the box be ~~~ed or summat cheers
            • wilf
              • 1618
              once loaded with an image, it needs the magic files putting on mate watch this Digital Kaos - - How to set up a dreambox
              The image is not what opens the channels if you do a factory reset it would delete the keys and roms, the image from what was on when you had it working was fine it just needed the files back on mate
              • woodgm
                • 14
                rite got tht sorted now but the ip address keeps cumming bck as 10.0.0.5 which ino thats wrong what am i doing wrong cheers
                • wilf
                  • 1618
                  not sure what them numbers mean? after you connect to the router via ethernet cable did you reboot dreambox then go into get the ip address
                  • woodgm
                    • 14
                    yh rebooted box go into communicatyion setup and ip is cummin bck as 10.0.0.5 dhcp is ticked netmask 255.255.255.0 the type is lan nameserver 10.0.0.1 same with gateway enable network ticked port 80 cheers
                    • wilf
                      • 1618
                      all i can think of is that commando image is no good try putting the dk image on thtas what most have without any probs
                      • woodgm
                        • 14
                        ive put that on mate but still no joy i got sent the commando image and he said it would have everything on it only thing i cud think of is that the coxial cable is not in the cable in lead but i wunt have fort tht wudda made a difference because i had it plugged in earlier and it was still cummin bck as same ip
                        • wilf
                          • 1618
                          its an open media right? so it has four connectors on the back for sat and cable they are usually all marked input cab or sat the bottom two for cable, also there is a switch next to these that says c or s it must be on c if setting up cable side. are you also sure its an ethernet cable and not a cross overcable?
                          • woodgm
                            • 14
                            yeah its open media 500cs yh theres all 4 connectors i dnt have nowt connected to them at the moment i tried it earlier with the cable lead in the cab in but still didnt make a difference still come with the same ip. its bin on cable havnt touched that switch n yh it will be ethernet.
                            • wilf
                              • 1618
                              sorry im at a loose end with this then at the min if owt else come to mind ill get back to this thread mate. hope someone else reading it can put you straight. good luck!
