Faulty openmedia?
  • waqasahmed
    • 433
    Faulty openmedia?
    Hi, all I plugged my scart from my TV to the TV scart of my openmedia receiver, but I got really high contrast colours with no sound at all. I then connected my scart from my TV to the VCR port of my receiver, but I got a lighter look than before-I had black menu's before. Now it was more like a transparent black like with Vista/Windows 7 when windows are maximised. I have also noticed that it has yellow, red and white ports-what would you call these things? As I dont mind using them if they work
    Lose your memory sticks? Forget to backup? Why not get 2GB of free space online, and I get 250MB too
  • on_the_jazz
    • 557
    The vcr output on most devices is lighter. Not sure why but its something I've noticed before too.
    Have you tried a different scart cable? Also try changing the output type in the menu to something other than rgb (since your cable may not be rgb).
    Those other 3 connectors are for composite. You can connect the yellow one for video and red and white are audio. The quality of this is far lower than scart though. Personally I would avoid using them.
    • waqasahmed
      • 433
      yup tried that. Still get the same thing
      Tried that as well, just got a "no signal" message on my TV when scrolling through options
      Before this, I also flashed via dreamup instead of telnet as I normally do. Also, is there an up to date file for video settings? As Im suspecting that my TV is pal? Its fairly recent but before it messed up, it was using the RGB+CVBS option
      • waqasahmed
        • 433
        I took the main board out of the receiver thinking some solder points might have came loose as was the case with my other openmedia 500CS when the PSU board had a solder point broken, but I looked on this openmedia and I saw that when I moved the TV scart up and down, it wiggled a little more than the VCR scart
        • psats
          • 823
          do you get this fault on both sat and cable
          • waqasahmed
            • 433
            my sat setup is screwed at the moment, so cant really test that Also, this sort of thing happens whether or whether not a cable feed is in
            • psats
              • 823
              there is no need for cable sat feed to check the symtoms your saying your haveing #
              just try the box on sat / then cable/ see if you get same..
              • waqasahmed
                • 433
                psats, thanks for that info, however once I put my receiver back together(after pulling the board out) I reflashed it with a PLI Jade image seeing as though the DW one was in beta and enigma seems to have a better "feel" to it and to sell it off as faulty. I then switched the receiver on, and both scarts worked -before on my TV in the corner it said
                Scart
                Auto
                Now it says
                Scart
                Pal
                Maybe something in the settings as someone pointed out here, but there were no such settings for the DW image
                • psats
                  • 823
                  i have never seen that fault on my cable side of the box useing any of the uk modded images.
                  sounds more like a bad flash than image settings fault
                  • waqasahmed
                    • 433
                    maybe so, but I did flash the same DW image twice-once using telnet and the other time using Dreamup and waiting for it to finish
                    • psats
                      • 823
                      if you use dreamup and both cables its done in couple of mins
                      its nice to find out you got it working anyway
                      just wish i had a magic wand to fix my sat tuner
                      • waqasahmed
                        • 433
                        Most of the time I only use telnet as its slightly quicker
