easiest option
  • qwertyballs
    • 26
    easiest option
    hello
    I have a eurovox that worked like a dream. I moved into a new place but it doesn't have cable. I get digital freeview by connecting to aerial socket in wall. I was told this is satellite feed. If I connected open media to this socket can I pick up channels?
    Vrgn describe these new build apts in Belfast as a non cabled area and we can't put up sky satellite dishes so I don't know what to do
    Any help is much appreciated
  • clit-eastwood
    • 339
    Ask your neighbours if any of them have sky, if they do, you will find that there is probably a communal dish on the building somewhere. A lot of apartment blocks are not allowed to have individual dishes, so they all share a comunal dish.
    • qwertyballs
      • 26
      do you mean to get a sky basic package in? Any chance open media would work via ( satellite) aerial socket?
      • clit-eastwood
        • 339
        eurovox wont work with a sky dish, you would have to get a compatible box for sky
        • qwertyballs
          • 26
          yes, I will get open media box. Just hoping it might have been able to pick up a feed from satellite that currently provides freeview
          • clit-eastwood
            • 339
            Yes that would work, also download the firmware to get all the rest of the channels.
            Good luck
            • qwertyballs
              • 26
              Good luck
              thanks. 500cs ordered. Fingers crossed
              • qwertyballs
                • 26
                ok, got the box, did a scan on my satellite feed, only satellite name found was something like PANAMSTAT 1R
                is this an actual satellite found or a default?
                • max_gee
                  • 108
                  if you are connecting it to a communial dish then more then likely its facing 28.2% what you do is select 28.2 or Eurobird from the list. make sure nit option is selected (if using the neutrino image) and do another scan
                  • qwertyballs
                    • 26
                    How do I select the satellite? I only get PANAMSAT 45 degrees. No other choice. I was using directional button
                    Am I doing something wrong?
                    • aftermath
                      • 4345
                      Originally posted by qwertyballs
                      you will probably need to enter your longitude and latitude , in your sat settings for your reciever to understand where the dish is.
                      Worldwide map search, route finder and travel directions - powered by Multimap that will help you find it.
                      • qwertyballs
                        • 26
                        ok thanks!
                        Would this get entered in setup? Manual talked about setting language, time etc but mine was already set
                        All help appreciated
                        • aftermath
                          • 4345
                          cant remember exactly, as i dont have open media right now, but think its in the sat location, or DISEq2 . something like that, should be one of the first options when you have re flashed box and re started
                          • qwertyballs
                            • 26
                            what is reflashing? How do I do it?
                            • qwertyballs
                              • 26
                              All sorted. Thanks max_gee!!!
