Problems with the motor
  • calisto
    • 37
    Hi,
    Wonder if anyone can help?
    Have set up the cable side of the box & just setting up sat side of it.
    Have got the latest Eagle on image & all is working fine moving fromm 28e to 31w but will not go past those settings even though they are there on the image & the box tells you it is moving. Had Inno on it before & the same thing, can move it by hand remote. The motor is Satcatcher from Wizard, about a year ago.
    Calsito
  • father ted
    • Feb 2008
    • 1389
    hi m8 can you re-set the motor itself?does it have manual buttons on it so that when your up the ladder you can turn it ?i found i had a problem with my motor when i first got it but found it only needed reset i see from your post that youve had it over a year so im assuming it was working b4 so what has changed ?
    • aftermath
      • 4345
      could be the motor mate. Might only be programmed for those sats.
      is it DISEqc 1.2 ?
      should tell you in your manual what it will turn to.
      also make sure you enter your Longitude and latitude in the usals settings.
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        The image is probably designed for the whole world. Even though the sat positions are there on your box, doesn't mean the motor can physically travel to that position.
        Have a look at the position of the motor at 28e and 31w, does it look like it can travel further? Are you locking onto sats between 28e and 31w? If you are I don't see a problem.
        Because of the curvature of the earth, it's not possible for you to lock on to every satellite in the world. 28e and 31w are probably about your limits.
        • aftermath
          • 4345
          I know mine will reach between 42 east , and 43 west, but on the later ones , i dont pick up much , only 1 or 2 channels and not worth having TBH.
          • Curious123
            • 2591
            Have a look at your manual, it could be limits set by the motor by default.
            • .: JaCkPoT :.
              Retired Sat TV Addict
              • 5607
              Make sure you delete all limits on the receiver as this could be the reason. These limits are used so the dish doesnt hit walls and trees. Anything past 30west isnt worthwhile but going east most sats till 68.5 are good so i wouldn mind 31w but i would mind the loss of the eastwards ones.
              ___________________
              In the good old days, I had
              DM800s HD
              Openbox S10
              TM500
              DM500s
              90cm FortecStar dish
              Maxx 110cm Dish
              Technomate 2300 Motors
              • calisto
                • 37
                Thanks to all for getting back to me.
                It's my cousins box & he had an Inno on it before but the motor was not set up right & he could only get Nova on it, what he wanted cos he is the orginial Nick the Greek.
                Yes it has got manual buttons on it & can move to Hellasat(which has got more Greek progs on it) but when you move it back to say thor it will not go back to 39 e.
