Widescreen Switching on 500cs
  • cathy_c
    • 10
    I am having problems activating WSS on the cable side of the 500cs
    I am using the Enigma firmware and cant find any settings that work for WSS
    the previous Kaos image i used also refused to WSS
    I cant work out if this is a hardware or software problem
    Would a different image be the only solution?
    I am using a Scart>3 RCA component lead and had no problems with WSS on my sagem Dbox2 using the same setup
    This is really annoying as overall this is a fantastic box
    Any help would be welcome
    C
  • max_gee
    • 108
    you can try the neutrino based image and see if that makes a difference as it has the "auto option" as well as the 16:9 and 4:3
    or with the enigma image you can try the "disable WSS on 4:3"
    but to be honest none of these may work as Pin 8 on the TV scart on the openmedia box sends out a signal which determines the picture mode
    if pin 8 is 5-8v then tv will turn to 16:9
    if pin 8 is 9.5 - 12v then tv will turn to 4:3
    so if using component i cant see how the tv will know what mode to go in as the component leads do not carry any additional info about picture mode.
    • cathy_c
      • 10
      OK its all sorted now
      Although component does not support Aspect switching
      I have connected a scart lead from the VCR output into my HDD recorder and it now switches aspect even when viewed through the component when the HDD recorder is in stand by
      • mohamed_msk
        • 5
        can any1 send me a firmware for Open Media 500cs. thanks
