Scart socket hum
  • bigman2
    • Oct 2008
    • 52
    Scart socket hum
    I was using my openmedia box via the wire that came with it but today deceided to wire it up using a scart lead. However when I switched to the relevant AV channel on the television I could not hear anything apart from a strong electrical hum.
    I switched back to the wires with the box and plugged them into a scart socket and it worked fine. I have tried a different scart lead but it made no difference.
    Is this a known problem ? or is there some setting I need to change ?
    Besides this problem it is a great little box.
    Thanks in advance
  • portbhoy
    • 717
    It is a great wee box but it is also very cheaply made I know one that smoke started to pour out of it I would return it as faulty theres obviously something not right in there!
    • .: JaCkPoT :.
      Retired Sat TV Addict
      • 5607
      Could be one of the audio input pins which are damaged.
      Get a audio video cable and on one end put a scart adaptor. Put the scart in the receiver and the wire end in the tv. Then do it vice versa. Check the if the combination equates to a hum or not and take a note. This will narrow the prob down.
      ___________________
      In the good old days, I had
      DM800s HD
      Openbox S10
      TM500
      DM500s
      90cm FortecStar dish
      Maxx 110cm Dish
      Technomate 2300 Motors
      • psats
        • 823
        try useing a NONE fully wired scart {one way}
        plus you can get that hum if you not got the suppressor on the incomeing feed
        • .: JaCkPoT :.
          • 5607
          What one of them?
          ___________________
          DM800s HD
          Openbox S10
          TM500
          DM500s
          Maxx 110cm Dish
          • portbhoy
            • 717
            mee maw mee maw mee maw, thats a sound Mept's familiar with
            • .: JaCkPoT :.
              • 5607
              I dont know about you but our fire vans dont sound like that.
              Do these catch fire that easily? Its better to just set 10 tenners alight
              ___________________
              DM800s HD
              Openbox S10
              TM500
              DM500s
              Maxx 110cm Dish
              • portbhoy
                • 717
                Do they not, it used to be ne naw ne naw, them wooo, wooo, wooo, wooo but now it's me maw, me maw. It's the only one I've heard of thats went on fire when Mept opened it she said it was quite messy in there with loads of the red stuff they sually cover the screw heads in
                • .: JaCkPoT :.
                  • 5607
                  Hopefully the scart isnt damaged. Scart is meant to be higher quality.
                  ___________________
                  DM800s HD
                  Openbox S10
                  TM500
                  DM500s
                  Maxx 110cm Dish
                  • bigman2
                    • Oct 2008
                    • 52
                    Thanks for the suggestions guys and to max who offered to replace the box.
                    I had another play with it using another television and used a cheap scart lead with flat ribbon and the problem appears to have vanished. I think the fancy scart leads I was using may be a bit connector heavy and may not have been making proper contact with the female scarts on the television or openmedia box. Plugged it all back into the original television and no audible hum yet.
                    I guess no more fancy heavy scart leads with gold plated connectors from now on.
                    • portbhoy
                      • 717
                      Glad your sorted mate, just for the record my box works fine and I'm very happy with it for the money it's a solid buy
                      • bog1
                        • 76
                        o.o im on my 2nd box and i got the hum too o.o
                        • bog1
                          • 76
                          can you tell me ware you got this ie scart lead ribon as iv side im on the 2nd box and got the humm too allso im geting gosting from the menu too =( i can get hold of max ther phone is nother anserd my be fult on the line
                          • max_gee
                            • 108
                            im not always able to answer the phone but email is best way to get hold of me
                            • bigman2
                              • Oct 2008
                              • 52
                              Try ebay and search for flat ribbon scart.
