trouble downloading fix to starview 2
  • tombhoy
    • 4
    Hi All,
    I am new to this so I might be suffering from finger trouble.
    Trying to download 802E fix.
    Started by doing a factory reset. (advice I saw on this forum)
    Have opened the v4.03_051005 loader, and selected bin file.
    When I hit download i get an error message
    "Can't open serial port".
    I have tried selecting com1 - 4 as serial port and get the same error message.
    Any advice would be welcome
  • dell_xps
    • 2558
    Originally posted by tombhoy
    Hi All,
    Are you using an rs232 null modem cable or a usb to rs232 adapter m8?
    There is a new fix out for The Box,
    • tombhoy
      • 4
      sorry, should have said - I am using an rs232 cable
      Tom
      • madAD
        You sorted yet mate? I had a right game with the sv2 but have cracked it now, not sure if i have done everythin right but had to download 3 bin files to get to work!
        • melloned
          • 1215
          Once you've made a coms port connection Mate , just use the latest box fix found on this forum.
          When you open it , you;ll find V4.54 firmware , which you'll have to load first , if your box is on the old V4.51 , when you've done this , flash over it with the logo file , also found in the fix file , and for your last trick flash on the latest V802 firmware and you're finished .
          Hope this helps , all the instructions are also in this file .
          • tombhoy
            • 4
            Many thanks for the info guys.
            I eventually loaded k**s and things are OK again.
