starview combo satellite side
  • mrscoops99
    • 54
    i have the satellite side of this up & running but the CCCam side connects for about 10 seconds then disconnects the Newcand part is fine can any help with the CCCam part
  • irishbluestaffy
    • May 2010
    • 611
    try re flashing the box with f521 then put it all back in if that dont help have a word with the peson u got the cccam off
    • mrscoops99
      • 54
      will try this out thanks
      • neilvic83
        • May 2010
        • 27
        Hi mate, you need to make sure what format you r getting from the server, check that 1st... pm me if you want more info.
        Hope that helps
        • networks10
          • 23
          can anyone tell me if you can setup s/v 7 lan for sat side.
          • irishbluestaffy
            • May 2010
            • 611
            no m8 sv 7 cable only
            • budgie21
              • Apr 2011
              • 4
              is starview running in scotland yet thanks
              • mrscoops99
                • 54
                as far asi know sv 6 &sv 7 are
                • william1956
                  • Apr 2011
                  starview firmware
                  does anyone have set up instructions for installing starview hd combo lan firmware please.
                  • iphonic
                    • 244
                    Load the file on a usb plug the usb into the box and then go to the usb option make sure you use the correct firmware and look for the firmware on the usb menu on the box and then click on it and do a software and data install then rescam for sat channels, im using knightrider firmware for the sat side as its stable for me
                    • keith 555
                      • Feb 2011
                      • 48
                      if u know what ur ccam details r take it of then reset on ur box then turn boxs off for about 20 mins restart ur router and then reboot box put in ccam detail and should work fine iam useing kinghtrider file 0712 and updated sky fav mar2011 hd and all working fine. it could be ur sever that ur on can allways try another test line to find out
