Is starview server down again
  • khoda7
    • 179
    Hello peeps
    is starview server down cos i just installed new fw via options usb and s/w upgrade
    dont c ustream option anymore so cant turn it on
    wen i select auto and apply ip add it stays 0000000 on everything
    router is fine and internet is working on computer
  • mark080270
    • Oct 2008
    • 36
    just go on any channel and type in 1819
    • khoda7
      • 179
      iv got sky sports 1 running but it freezes for a few minutes and cums bak on den freezes agen
      any1 else having same problem my internet is running fine
      • khoda7
        • 179
        showing up as not connected den connected den not connected den connected
        any ideas
        • shaunwall
          • Feb 2011
          • 74
          no mate working fine
          • barbellrow
            • 62
            teething problems at the other end guys id say. just some patience as all channels aint bk on yet so fingers crossed and we will all be in buisness by the end of the week my sv being temprimental but worth the wait thanx guys at the other end for bringin the sv bk to life
            I saw a billboard on the way to work this morning that read "Future Events."
            Well, that's a sign of things to come.
            • khoda7
              • 179
              how cums mine keeps freezing
              • khoda7
                • 179
                id jus like to know if its problem on my side or their side
                • khoda7
                  • 179
                  also noticed net application ustream option is not there anymore
                  any1 else with same problem
                  • shaunwall
                    • Feb 2011
                    • 74
                    they said it would go down for a bit because they will be putting more channels on
                    • peggybobby
                      • Sep 2009
                      • 33
                      @khoda7
                      you dont give much info mate?
                      are you using homeplugs or hardwired from w/router
                      do you have another box on your router maybe one for sat side
                      or 2 cable boxes on router with the same ip can conflict off on off on connection problem
                      rgrds
                      peggybobby
                      • iphonic
                        • 244
                        Thanks peggybobby for the pm
                          really
                          • lincsat
                            • 1228
                            They do not use Ustream any more, so don't worry about that. If your IP is all 0's, then you do not have a good internet connection, nothing to do with the server.
                            It's also worth checking your signal quality, as before, it needs to be above 65%, the new firmware cannot do anything about the signal strength on the VM feed and you will still get freezing or no picture if the signal is not good enough.
                            • scott8999
                              • 14
                              i have had no problems with this my ss1 and ss3 runs smoothly have you checked the cable feed ?
