The Box Super USB V1.12
This topic is closed.
  • Glynn831
    • Jun 2009
    #166
    Originally posted by bigshak
    i switched my box on today as usual and i have lost sly spots 1 and 2 and 3 also sly modern, i only the other day did a full factory reset and scan and new firmware so im a little peed off about it...any ideas guys? im in birmingham uk tw
    The same happened to me I had Firmware version 1.07 on and had only limited channels so put Firmware 1.10 on rescanned checked KEYCODE was on and I'm up and running again.
    Might sound a little stupid....but............. have you tried rescanning? also have you done the MENU 1570 and making sure that KEYCODE is turned on?
    • mtv1
      The Stig PT
      • 4413
      #167
      moving transponders is a way of getting you peed off just do what u did before u dont have to update filmware just make sure you have the latest one stick with it m8 good luck
      • thehuddle
        • Jun 2009
        • 7
        #168
        thanks for the help yesterday finally got the box up and running.i wasnt going into hidden menu and setting the default key thought you only had to turn emu on. thanks again
        • Salmanazar
          • 19
          #169
          Thanks for the help. Had a few more repeated attempts and it looks like the problem is the file extension being "BIN rather than 'bin'. Doesn't seem to make a great deal of sense but when I renamed it, it worked first time.
          All done now though.
          S
          • undercoverjamil
            • Apr 2009
            • 184
            #170
            funny i just noticed this new firmware today.
            can i just ask what does this one give you over 1.07 in the u.k.
            • admoson
              • Jun 2009
              Thanks for the educational material
              • boomer39
                • 2818
                #172
                apparently epg is more stable, and works faster. so satsmo says..ynwa
                YNWA..
                • brenwall
                  • Jun 2009
                  Starview 4 not working in ireland for months....going to give this v1.10 a try....fingers crossed....cheers
                  • kennytabs
                    • Jun 2009
                    #174
                    new F/W V1.10 work's in ireland.
                    Works a treat m8, back in business thx satsmo,
                    newie in cork.
                    • percy
                      • 6
                      #175
                      Help
                      My box is stuck on Info data being updated
                      • mtv1
                        The Stig PT
                        • 4413
                        #176
                        reflash it m8 hit default key good luck
                        • undercoverjamil
                          • Apr 2009
                          • 184
                          #177
                          alright but the only difference i have noticed so far is that when u press epg it does a full download itself.
                          • mullinz94
                            #178
                            Thanks a mil up and running in cork
                            • mullinz94
                              #179
                              Originally posted by satsmo
                              Latest firmware release 05/06/'09, for the Box Super USB, (SV4). Version 1.10
                              Contains Nagra 2 fix for Ireland. Can be used in both the UK & Ireland. Please see link for change log
                              Digital Kaos - Downloads - Starview 4 USB Version 1.10
                              Thanks up and running in cork. Well done.
                              • dragon77
                                • Jun 2009
                                Starview 4 the box super
                                Can anyone recommend this box? is it easy to flash
