Works! Doesn't Work!
  • imamon
    • 9
    I followed some instructions and loaded the software fix and eventually got the box working at my mates house, but when I got it back home and plugged it all in the message no signal! keeps coming up and all the bars eg. signal are blank.
    I have had it working on this connection previously. Any thoughts
    Regards
  • satsmo
    • 6397
    Sounds like a cable/signal issue. Have you checked your cabling and take away the splitter if you are using one.
    • imamon
      • 9
      I don't have a splitter, it's a direct connection which i have used about 3 months ago
      Regards
      • satsmo
        • 6397
        No signal usually means just that. Does your mate live in the same provider area as you?
        • imamon
          • 9
          Yes about 200 mtrs away
          • satsmo
            • 6397
            Do you have a subscribed box and is that working at the same feed?
            • imamon
              • 9
              No subscribed box
              • daveb1111
                • 26
                hi
                i use to work for vm and it sounds like your cable may have been diconnected at the main green cabinet at end of your street or nearby, if you plug your cable direct into your tv ant socket and scan, if you have a signal it will act like an ant and pick up your normal tv chans and maybe a couple more, if not connected you will not get these, this should show you if cable is connected at cab .....dave...
                • imamon
                  • 9
                  I think that might just be what it is, might have to get subscribed for a bit....
                  • satsmo
                    • 6397
                    Always advised to have at least a minimum sub.
                    • daveb1111
                      • 26
                      or a cab key ha ha ha
                      dave.........
                      • daveb1111
                        • 26
                        hi satsmo
                        can i just take the opp to ask if you can help, i tried to get a friends eurovox 1000 on and it wont update , i used new firmware advice from yourself and rebooted and powerscan still only free view and others are updating code all time
                        • satsmo
                          • 6397
                          True a yellow jacket also works but thats taken the pish a bit
                          • satsmo
                            • 6397
                            Originally posted by daveb1111
                            hi satsmo
                            Dave start a thread in the Eurovox section and I will take a look
