hi guyz, i've got my starview hd combo working on the sat side, but recently the picture's been freezing frequently, so somebody advice me to use knight rider uad file to load it on the box, but duno where to get the file from. cheers in advance
Thats the exact same issue i was having with mine i will pm you. Also check googleLast edited by iphonic; 4 April, 2011, 14:03. -
sv combo
i use the guiness hd ccam fix f/w on my combo its a bit more stable than knightrider i think.it cud also be your servers you are using as well if your getting a lot of freezing nd glitching.check with them and also ive found the combo is a lot more stable if you use a n:line instead of c:line or newcam instead of ccam.Comment
iam useing the knightrider0712 with updated stb sky fav mar2011hd and been testing a few test line with it and is all ok with me f/w can be found on toolbar .if ur getting alot of freezing it could be ur sever that ur on or network and cable side is allways off .its a gr8 little boxComment
