The Box SV2
  • khenryashley
    • 783
    The Box SV2
    I Have flashed the new firmware 4.55 on my SV2 the box.
    It is now stuck with the digital display dispalying On.
    Will not switch on or off with remote.
    Anything I need to do.
    Ash
  • curve
    • 5
    Have you tried the fix by zran on december 4 it's back about 7 pages.
    • ramjet
      • 2995
      turn it off , then start to reflash with v4.54 firmware , then let it reboot and factory reset it and test it works
      if its ok and says 4.54 in system info , then flash it with v4.55 again and let it reboot , factory reset from menu and check its ok
      if ok turn emu to on and hit set keys default with menu 1570 secret menu screen
      • khenryashley
        • 783
        I will give it a go 2moz and let you know.
        • khenryashley
          • 783
          Many thanks
          I will give it a go and let you know.
          Ash
          • khenryashley
            • 783
            Thanks curve
            Followed the instructions to the letter and it worked perfect.
            • khenryashley
              • 783
              Thanks Ramjet.
              Everything up and running.
