SV4 Recording problem
  • tony_i
    • Oct 2008
    • 425
    Often when I use the epg on thr sv4 to schedule a recording to my hdd it will start okay but then decides not to swith itself off.
    Anyone else found the same problem and more importantly a possible solution?
    Thanks in advance.
  • Smokey786
    • 35
    I'm getting the same problem, I schedule a record and the box crashes or when I try to record 'from now' again it crashes... have to switch off from the back and back on!
    I don;t know if it has anything to do with the external h/d which I have, but it has been formatted by the box and still no joy! Any help appreciated !
    • tony_i
      • Oct 2008
      • 425
      Right...so a completely different problem then?
      • good2know
        • 47
        have you tried the v1.06 firmware update
        i used a 16gb flash card and reader straight into the box, i noticed when i first started to use it it didn't fit in the slot completely cause of the position of the usb being next to the output and using a wide card reader...
        this would hang the system and i would need to switch off the main power to re-initalise it.. i put it on a usb extention cable and it seems to be working fine on mine now...
        best i can offer
        good luck
        G2K
