When u install new sv7 software showmustgoon2.12 do u have to do bootloader s/w and software s/w updates or just software updates?? iv got a new box should i put carling bootloader s/w and s/w update then showmustgon s/w update???
WHEN U INSTALL NEW SOFTWARE TO SV7
so whats the bootloader s/w option for on sv7 ???
From the main [COLOR=#0066ff !important][COLOR=#0066ff !important]menu[/COLOR][/COLOR] go to Utility and then press the right arrow button and select usb
from the right hand side, you will see the Carling/Guinness file press ok on it and make sure to select SW+ALL DATA UPDATE.. mines has bootloader and sw ?? separate options??Comment
a brand new box will be a virgin as in no s/w update available
it will have to be flashed by usb stick first,and hopefully you can get a connection,if it is not flashed i would consider returning for a refund as many starviews are not connecting,will you be an extra non connector.Comment
