Starview 7, been away ? whats going on? on
  • sshhiinnee
    • Nov 2010
    • 83
    Guys,
    Right been away, i last updated the software in June, showing the expiry date on Nov 2011 on my SV 7.
    Been away from T.V.......&
    Now im getting not connected? and geting ip: 000.000.000.000
    looks like im not getting conected to the Sever?, my internet works fine..?
    Reflashed it again and again.....what have i missed. this was a brand new box purchased in Feb 2011.
    cheers
    You are having the internet connection issues as in any circumstances it should show you your IP address, menu, option, network, press IP setup and if you can not see your ip address your broadband is not connecting mate.
    • ramjet
      • 2995
      its the lan connection that is failing , ie:- the ethernet connection to the router , nothing to do with the broadband , yet
      once the lan is up and running , then check the server connection is working via your broadband
      so in laymans terms , get the connection to your router working properly , which is your responsibilty
      • b2k
        • 32
        Originally posted by sshhiinnee
        Guys,
        cheers
        Sounds like your adapter on the rear of the box is faulty as others have experienced.
        Assuming your Lan cable/router are fine.
        • sshhiinnee
          • Nov 2010
          • 83
          im getting internet find on my laptop, ive tried pulling the ethernet adaptor out and re-attaching, rebooted router,
          still getting not connected and 000.000.000.000
          ive tried changing the ethernet cable, aswell still no joy...
          i do have a wlan extender but that is switched off.
          i am using homeplugs which both are connected and all connections are fine...
          if it is the rs32 adaptor can i use the usb to ethernet adaptor or use and extension on the usb to use the external hd, and usbport for the ethernet connection...
          cheers..
          • Kezman
            • 15
            How can this be fixed?
            • mark8393
              • 2305
              buy another. main traders would of had faulty units back which they cant return, so they sell adaptor to recoup some cash.
              • cactikid
                • 12017
                so new adapter + sub=or new box?
                • sshhiinnee
                  • Nov 2010
                  • 83
                  After borrowing my mates serial to lan adapter..and messing around with it, im still getting not connected...
                  however when i changed my homeplugs around from the router to the wall socket..i did pick up an ip address on the Sv7..
                  which is good...however...strill getting not connected.
                  in the system info..i see box number and no expiry date?
                  this is driving me insane..any other ideas?
                  the ip on auto im getting is...192.168.1.103....
                  i do have a wlan extender but that shouldnt matter as this works with 1 other manin homeplug connecteed via the router?
                  • ramjet
                    • 2995
                    sounds to me as if the lan is now ok but you havent got smgo221 firmware on the box
                    • sshhiinnee
                      • Nov 2010
                      • 83
                      ive flashed with the latest 10/06/11 show must go on file...
                      now im still getting no ip address...and under the system info
                      i see the ram data and box number this was all working a couple of weeks ago...until i got not connected after coming back from my holiday....
                      help needed.... all adapter serial to ether is working as used different ones from working ones from my friends...
                      im getting internet connection working fine on laptop..so wifi is working with router...
                      im using orange homeplugs with ethernet cables plugged in, ive changed the cables aswell to no avail..
                      ive checked cables and connections.....
                      help please...
                      • mark8393
                        • 2305
                        Have you paid your sub? ?25 for 6 months, ?45 for 12
                        • xraydelta101
                          • 75
                          its rip off time mate
                          • ramjet
                            • 2995
                            help please...
                            until you get an ip address from your router over your lan , nothing is going to work apart from about 17 fta channels
                            so suggest you test the homeplug system with your laptop and ensure its working properly , then make sure your sv7 gets a local lan ip address from your router , once done , check the expiry date
                            • brainwave
                              • Mar 2009
                              • 209
                              And after that if your box says not registered, well what can i say stick your hand in your pocket again, and pay for support for 6 or 12 mts, as that is the only way you are going to get your viewing back.
