Set up new starview 4
  • linda richardson
    Hi just got the starview 4 super USB. Inside the box it gave information
    to download onto usb from TheBocSuperUSB_V1.02_betaBIN
    I have done this got the free chanel but all other chanels said downloading data and just stuck at that for hours, Help how can I get further on,
    sorry if its a stupid question but brand new to anything technical, it took me
    half an hour to post this thanks Linda
  • hunta
    • 7
    hi you need to download 1.07. Go in to downloads you will find it there then put it on to a usb stick and load it onto your SV4
    • linda richardson
      Thank you so much I'll try this and let you know
      Linda
      • dell_xps
        • 2558
        To view the $ channels, press menu on your remote, then 1570 on the remote, you will now see a secret menu, move it down to EMU it will be off, select it and turn it on, exit back to $ky sports 1 and let it update.
        1.2 is older firmware you have there, as the above poster pointed out,download 1.7 put it on your memory stick, put it in the starview, go into the menu select hard drive and flash it with the latest firmware.
        HTH
        • bigfella
          • 879
          linda the emu is also known as the keycode on the usb so if u select this turn it on and then press default.exit to sly sports let it update ..you shud be ok ..hope this helps ...bigfella
          • forkoff
            crack
            whats the crack then
            • chunder
              • 91
              the crack is ninety.
              yourself?
