starview 3 birmingham
  • paul mac
    • 9
    just lost the lot, uploaded latest 8.04, no joy showing full reception, any ideas?
  • bigfella
    • 879
    can u get to the menu? ...if so do a factory reset ..dont forget to turn the EMU back on and press default ...hope this helps ..bigfella
    • khenryashley
      • 783
      What is showing on the screen or the box.
      Can you get in the Menu
      • paul mac
        • 9
        starview 3
        channel number showing on box, yes can get into menu
        • bigfella
          • 879
          firstly check if u ve had a successful flash with the new firm ware goin to menu...system set up...system infro...shud tell u which firm ware is flashed to ur box....if that is rite ...then do a factory reset..choose english..autoscan..select correct local cable provider...scan....open EMU by pressin 1570 on remote ..press emu on then default on then exit to sly sports and wait for updatin ...hope this helps ..bigfella
          • paul mac
            • 9
            Big fella your a diamond
            • bigfella
              • 879
              ... if everything else fails turn on and off at back of box ...relash and try again ..hope this helps ..bigfella
