Unable to open program to subscribe SV6
  • deano77
    • 4
    Hello All
    I don't post that often as i normally sieve through 100's of posts to find my answer & save on space & hassle to other users .
    Yep I have a SV6 box and yep i'm licking my wounds but i'm not greedy and was all good while it lasted
    But problem is now that i am struggling to open the exe file to subscribe i have tried downloading the net.framework but still won't open could anyone please PM me a direct link.
    If this has no effect the only boxes i have used over the years are all have been SV's from the box - super up till this sv6 so am pretty narrow minded on other boxes with no experience at all i have cable fitted and also a dish up but unsure of any other box which would be good for a novice so any help or advice would be appreciated
    Thanks all in advance
    No genius but i'll ave a go for ya ....Stand back!!....
  • deano77
    • 4
    Thank you for your replies .. .. I am going to look into it now and see ...
    I will keep you informed thanks again ..
    • DigiKing
      • Jul 2011
      so your having trouble?
      what u need to do is flick the switch at the back to off, then what u do is while switching it on hold the channel up button and it shud come up with reset on the led display then you will come to a menu where various options will come up then simply just press ' 0 ' then it will say switch the box off and on.. once you've done that step it shud go on the menu of the starview box, hope this helps. Good luck.
