starview 3
  • jimbojimjay
    • Oct 2008
    • 149
    starview 3
    got sv3 but only picks up fta what software do i need to get cable programs i am on v i dont think there is any software on it do i download something from here thanks
  • spondulick
    • 677
    just go to menu hit 1570 on remote, scroll down to emu make sure its on if not turn on reset default key exit out to sky spts 1 should update
    • khenryashley
      • 783
      You need firmware V 8.04.
      You can find it in the sticky download section.
      Let me know if you need any more help.
      Ash
      • bigfella
        • 879
        goto dpownloads .....click on firmware u need ..
        Ensure you have the Right firmware for your box (make sure its not a clone box)
        Use GTrom to update downlown
        * You can leave it on default settings usually, (COM1/115200)
        * Click on BIN File and select the new firmware.
        * plug your box into the PC using null modem cable
        * click on Download.
        * Wait till it says completed and your done. goto menu .goto menu. goto auto installion ..select your local cable provider eg ntl,cablewest etc then press auto scan..... wait till it scans.....
        once you have flashed your box you need to turn on thre emu to access the dollar channels you do this by goin to menu pressin 1 5 7 0 on your remote which opens the secert menu .you then turn on the emu and then the default ,,exit 3 times to s** sports and it shud update wait till it reaches 100 then it shud be ok ,,,hope this helps bigfella you can check wat firmware is on ur box by goin to menu ..goto system setup then system information and it will tell u wat got
        • jackd
          • 67
          my box wont find any chanels ive updated it to 8.04e
          • jckw
            • 760
            turn emu on go to menu then press 1570 then turn on ur emu
            we are all learning each day
            • khenryashley
              • 783
              Jackd
              I have noticed you have posted the same question on another thread.
              Please try and stick to one thread so we can pick up on your problem.
              Please let us know what you have done so far. Have you done a factory reset before rescanning.
              • martin-f
                • 535
                do you have any channels ? if not you will have to do a rescan menu select your provider ie> t/w n*l c*w then auto scan> turn emu to on then exit to s*y sports 1 to update
