Hi all ,Newbie in Dublin lookin for help with starview2
  • spursmad
    • 4
    Hi all , can anyone help with a dead starview in dublin .
    It went dead last week and wont reflash ... lookin for latest firmware and codes for dublin box on N*L...
    alsdo can anyone tell me how to attach the logo file to firmware.
    Thanks in advance....
  • cactikid
    • 12017
    why do u need to reflash it,what was running on it? did u reflash it in december?what do u mean by dead?more info needed if possible.
    • camelv
      • 1202
      as cactikid says m8 you need to be a bit more specific with the info you are giving.
      its the stuff we think we know that stops us all from learning
      • spursmad
        • 4
        sorry about the lack of info .....i have full menu and channel lists , but all chanels comin up blank saying no signal , my codes are correct in the nagra menu ... and i have done auto scan with emu on and emu off ... i have reflashed with api ver 450 e_E and Api ver 4.54e-E the second one being the original version on the box when purchased .i have made sure that my N*L (dublin) connection and my Scart connection are working .
        hope this is more helpfull ..... cheers
        • camelv
          • 1202
          do a factory reset m8 then go through set up again ,this should sort it.
          this is the most up to date firmware.
          • spursmad
            • 4
            http://www.digital-kaos.co.uk/forums...-loader-18314/
            Many thanks for your assistance guys .... ill give it a go .
            one last thing ..... where can i find the factory reset code for my box ..... lost the manual .....DOH.
            • jasbo7
              • 1432
              dunno if this is what your lookin for but you could look in here mate.
              • young
                • Oct 2008
                • 316
                factory reset code is 0000
                • spursmad
                  • 4
                  ulrika..... got it!!!!!!
                  Many thanks to all contributors , got it going after a bit of messing around .
                  heres the method :
                  switch on box.
                  enter menu,
                  factory setting,
                  enter password ,0000...thanks True Red...hope red is the pool?
                  click ok ..to reset factory settings .
                  Exit out to main screen .
                  disconnect ntl cable connection
                  connect null modem cable
                  swith box to standby mode
                  click GTR loader 4.03 ....cheers Camelv
                  click bin file 4.57...... cheers Camelv
                  press open
                  click down load
                  click ok when cms sending finished
                  disconnect null modem cable
                  connect ntl cable and switch box back on from standby mode
                  press menu
                  enter 1570 nagravsion menu
                  enter codes for dublin ntl
                  top bar = NTL
                  provider id = 54 01
                  press ok after storing each set of key numbers.
                  exit twice to main menu .
                  click installation
                  cable network set to ntl
                  down to manual scan and press once .
                  scroll down to network scan and press once to enable
                  exit back once and press auto scan
                  box will scan and find channels
                  exit out to main screen and all should be fine in your dodgy box world ........ this worked for me ....thanks to all the gurus .
                  SPURSMAD
